the belt should be on the center of the drum,
collect the loop on the botom
and feed the loop under and through the idler pully
take the loop and lift the idler pully, put the loop on the motor and release the idler
you should ba all set
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire...
(More)
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
The bottom half spins but there is no heat. The top half is working fine. I verified the duct is...
(More)
The bottom half spins but there is no heat. The top half is working fine. I verified the duct is clear of any debris. What else can I try or what part needs to be replaced
My son put in a small load of clothes to wash it filled the washer and then nothing. I have tried...
(More)
My son put in a small load of clothes to wash it filled the washer and then nothing. I have tried changing it to spin cyle or rinse cycle and the machine is still not doing anything. It will not even reset the water level. It is like there is not power going to the machine.
hi my dryer won't run at all . nothing happens when you push the buttons and all 8's show up and it...
(More)
hi my dryer won't run at all . nothing happens when you push the buttons and all 8's show up and it won't reset
