Question about Konica Minolta DiMAGE Z6 Digital Camera
Screen white camera turns on, but screen is white. Batteries is ok, the cd casd is ok, eyescreen is ok. I don't get an image on the LCD screen. Any ideas?
  • outaspaceboy Apr 29, 2008
    one day i just turned on my camera and the screen is white. Are there brightness settings on the screen that i've accidentally hit and now cant see the menu to fix it? or is the screen just f*$%ed?
If you are changing the lever to different positions...the green/edit, red viewfinder, or the red lcd view and get nothing...chances are your camera has the same problem mine does. The lever is broken and is not engaging the mechanism internally to change the views or power the lens to fully extend.
you won't be able to take pictures like me. I don't know if there is a fix or not. I guess the camera is prone to these problems as there are a few similar to what u describe with yours.
Posted on Feb 05, 2008
3/4 of my camera screen is all white and i don't know what could have happened to it because i haven't dropped it, but it has been in my purse for a long time, but nothing in my purse is heavy...
Possible that the LCD screen has failed. You can take images and load them to the PC.,If the images are clean then the LCD is a suspect. remove the battery for sometime and reset. If the fault occurs as a blank screen then the LCD must be taken out and checked for possible damage.
Jul 11, 2011 | Cameras
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
My camera Coolpix L20 is no working anymore. When I turn it on, the screen become white, nothing appears. The buttons's sounds it is OK, but no images appears in the LCD screen.
slap it into the lateral face , force the lens while turn on the camera, pressing OK while turn on the camera, it is risky but if you dont want to go to a shop camera you have to take this risk
Nov 03, 2010 | Nikon COOLPIX L20 Digital Camera
In the shooting mode no picture on the LCD monitor
I HAVE CANON POWER SHOT 620 DIGITAL CAMARA. NOW I WAS NOT ABLE TO SEE ANY IMAGE IN LCD MONITOR, LCD BECAME WHITE, TELL ME THE SOLUTION
Jan 30, 2009 | Canon PowerShot A75 Digital Camera
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung digimax i5
menu tab.
Samsung i5 camera
Try the following and see if this helps:
menu tab.
Aug 12, 2008 | Samsung Digimax i5 Digital Camera
Screen turns white or won't turn on
Try Energizer Lithium batteries.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
May 28, 2008 | GE A830 Digital Camera
Screen white
No Problem ABout battery. just take some photographs don mind whether you can see them on LCD Or not. Then Take Outr memmory and chek whether they comes using another camera. If its working then you need to chek with LCD screen Thanks Sangita
Jun 19, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
94 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
