Question about Lenovo ThinkPad T61 Notebook
Limited or no connectivity
How do I solve this problem
I have reset router
tried static IP's
used windows XP sp2 fix
used netsh winsock reset catalog
tried wireless and hard wired
this is for a number of users so their routers wouldn't all go at the same time although I advised 1 user to buy another router and everything worked
  • 55 Answers
When the limited or no connection comes up again, try right clicking on it and choosing repair. I hope this solves your problem
Posted on Dec 28, 2007
Smc router says limited connectivity and won't work.
I experienced the same issue before with my route,try doing these steps im sure this will work somehow. (flush the DNS cache)
How to do it:
If you are using Windows 2000/XP operating sysytem
-Fire up a Command Prompt (Start Menu>Accessories) and execute the command
ipconfig -flushdns
if you get 'could not flush dns' or message saying dns resolver cache could not be flushed.
If it is XP SP2 then go to Start > Run > CMD > type netsh winsock reset > enter, restart as prompted, if still no connection then go to Start, Control Panel (Network and Internet Connections then Network Connections -or- straight to Network Connections, double click on the Local Area Connection in use (usually the one that says Connected) and pick Support. Try the Repair button after Winsock fix. Use that winsock fix only if you are using SP2.
go to "start, control panel, administration tools,services,then look for DNS Client, and make sure it's started, and set to manual.
May 30, 2011 | SMC (SMC7004AWBR) Router
My recently added laptop is connected to my wireless router but can not access the internet...thanks
Try to do the following steps.
Go to run and type in cmd.
On a command box type in the word which is on bold letter.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Mar 21, 2011 | Computers & Internet
Router will not connect
Depending on what router or connection you are using try these steps.
Windows XP
1.Powercycle all equipment (Unplug)
2.Wait 15 seconds and plug back in.
3.Go to Start/Run/Type ncpa.cpl
4.Double click the connection you want to connect to
5.Click on tab next to General
6.Ensure that it is assigned by DHCP
7.Ensure It has a valid ip address It should start with 192.
8.Go to Command Prompt Start/Run/Type CMD and hit ok
9.Next to C: Type netsh int ip reset reset.log
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
10. Restart Computer
WINDOWS VISTA/WIN 7:
1.Start/Search Bar/Type ncpa.cpl
2.Right click on the Connection you want to connect to
and hit Properties
3.Uncheck Internet Protocol Version 6
4.Click on Internet Protocol Version 4 and hit Properties.
5.Ensure Obtain an IP address automatically is checked
Ensure Obtain a Dns Server automatically is checked as well
6.Exit out of everything
7.Go to Start/All programs/Accessories/Right click on Command Prompt and hit Run as Administrator then click continue.
8. Type: netsh int ip reset reset.log
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
9. Restart your computer.
10. If you are still unable to access the internet you may have a virus I would suggest running an Antivirus. I hope this Helped Good Luck
Oct 02, 2010 | Belkin Computers & Internet
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Wireless connection keeps failing
I have a similar problem with my Linksys G router. It is putting out a weird ip address through DHCP. While this does not fix the problem, setting up a static ip eliminates it for now. If I ever find out the cause, I will post it.
Jul 31, 2009 | Dell Latitude E5500 Notebook
HP LAPTOP DV9000 WLAN stopped working
Sounds like your wireless adapter has died you need to replace this ....
Nov 11, 2008 | HP Pavilion dv9000z Notebook
Linksys can't find ip address
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 13, 2008 | Linksys Wireless-G WRT54G Router
How to connect wire less connection with my laptop,
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
Acer Aspire 4315 can't connect to internet through wireless ADSL router
Reboot
Jun 09, 2008 | Acer Aspire 4315 Notebook
Edimax 4 ports broadband router wont connect
Try dong a TCP/IP stack repair Start -> Run -> Type CMD to open a command prompt. To reset the Winsock type this into the commnad prompt: netsh winsock reset catalog Next To reset TCP/IP type this into the command prompt: netsh int ip reset reset.log Then reboot your pc and see if that helps. If not let me know.
Sep 23, 2007 | Computers & Internet
Lenovo ThinkPad T61 Notebook Logo
280 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
