Question about Epson Stylus Pro 4800 InkJet Printer
Epson Stylus CX 4800
Morning - I was getting a flashing red light indicating change cartridge(s). Did change 3 of 4 as Yellow had half cartridge left. Tried to print but continually get flashing red ink (and power) light. I have checked that all cartridges are properly seated, turn unit on and off, unplugged / replugged, etc. all to no avail. Am I missing something? Any ideas? How can I print test page?
p.s. - I immediately changed out cartridges but did not do any apparent "change cartrdidge" function.
Thx for the ideas/help.
  • mamiller May 28, 2008
    I too have a problem with printing and I don't think its Vista related because I have been using them together for 3 months. I did all of the same steps as described above and even tried a test printing and they all just qued up. The one difference is that I had printed a photo that was to be 2 5 X 7s and it printed one and the bottom print was skewed or cropped and I can't get the lights to change from photo to plain paper or the number of copies to change. Neither of the Start buttons do anything like feed the paperHELP!!! may ann, almiller assoc@aol.com
  • Epson Master
  • 1,879 Answers
Actually, all you did was correct.
if it´s not the unit - hopefully the cartridges
call EPSON - prepare the date of purchase / place of purchase of the inks
Posted on Jan 03, 2008
Cx 4800 not printing quality colors
Are you using Epson Genunie Cartridges?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson Office Equipment & Supplies
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Cartridge holder does not move to
Hi
have you tried pressing it down for 3 seconds? on the printer utility on your computeris there an option to change cartridge? pls check that, if all fails then that's a hardware issue. call epson for replacement.
Hope this help
Dec 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Changing cartridge stylus cx 4800- cartridge cover is not cleared to remove
I called a life person who finally showed me that the ink was not completely used up, although, it kept warning me it was so low. I guess from what he said it turns an orange color when completely out of ink and then the cartridge holder moves over so that the cartridge can be removed. I hope he's right. I can still print. The directions would be more helpful if this was explained.
I take all information that I read literally and completely. I'm not computer savvy!
Nov 05, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Help with Epson Stylus CX 6000
I NEEED DRIVER OF INSTALATION OF IMPRESORA STYLUS CX 6000 PLIS MI MAIL IS marsa78_eva@yahoo.com.mx
Jan 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson 880
if red ink light is still on, check that the lid for the cartridge is fully seated
Dec 19, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Pro 4800 InkJet Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
