Question about JVC RX-664V Receiver
Speackers How many speackers can I connect to JVC RX664V?
  • 36 Answers
Hello 6423,
The RX-664VBK is capable of having 6 speakers connected to it, 2-front, 1-center, 2-surround and 1-powered subwoofer.
Hope this helps.
Posted on Dec 29, 2007
  • 1,175 Answers
Make sure that the "ohms" rating on the speakers matches the "ohms" rating on the receiver
Posted on Feb 24, 2008
Connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Feb 18, 2012 | Computers & Internet
Disconnect all your speackers and try switching on ,if it works you'll have to connect 1 speacke at time and switch on every afetr each to seen which 1 is shorting or overloading.
Sep 02, 2011 | Yamaha Audio Players & Recorders
I don't know which are the + and - exits for the speakers on my sony cmt-cpz1. I have bought new speakers and I want to connect them correctly, so now I am in problems, for there is no + and - indicated...
Plus and minus for the speackers are only to keep them in phase. You can safely connect any way. Then just experiment by changing the polarity on one speacker to get the best stereo effect.
Mar 30, 2011 | Sony CMT-CPZ1 Shelf System
Hello can u tell me how to wire in my car speackers as iv noticed its got 4 spade conectors on the speackers thanks kyle
The spade connectors are for wireing in (seires, 2 or more in 1Channell) or seperatly 1 speaker per channell,or output wires. you can hook them up straight to each output. 1 output = 2 wires. +,and a -. Make sure each one is hooked to the right one one the speaker. Possitive lead to possitive side of speaker.
Mar 06, 2011 | Orion Cobalt 93CX Car Speaker
The son froom my speackers stop
my best guess on this one is probably not the speakers but the sound system or device sending the signal to the speakers or the wiring to the speakers is shot if you are sure that all of this is fine then the problem is the speakers do not have enough power to play and it might be the psu that is shot.
Aug 22, 2009 | Yamaha HTR-6030 Receiver
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
The best speakers are the ones that sound best to you.
You should visit a hi-fi or dj equipment dealer and ask him/her to demonstrate some of their stock to you.
Take with you one or two discs of your own that you know well to listen to on their equipment.
If they do not want to do this for you, find another dealer.
Jan 22, 2009 | Technics SL-1210 Turntable
Denon Avr-588 setup
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
Jan 03, 2008 | Denon AVR588 Receiver
JVC RX-664V Receiver Logo
259 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
