Question about E-Machines eMachines Desktop PC
Emachine Desk PC T6216
I have a emachine T6216, When i start the computer it just goes full blast! It never kickover, I do not get anything on the monitor... Can anyone help! I was told it might be my Video Card.. Please if there is a Guru out there please i would like your ideas.
Thanks so much
Preston.
  • enforcer472 Jan 01, 2008
    The same thing happened to me the end of last week after all the updates. Fans and hard drive spin but no video. I got it up once and should have done a restore but thought it was ok and did a restart... Bad idea.
Power off the computer, remove the power cable, and remove the Ram sticks from your computer, then power the PC back on
if it beeps, that is a good sign, since it is detecting that their is no ram present (which the PC needs to load Windows)
if it doesnt beep, try removing all of your PCI devices and try again
if it isnt putting out video, however, and you have tried different combinations with the Ram, try another power supply, otherwise it may be a bad motherboard
signs of a bad motherboard include high fan speed (and not slowing down), the LED on the front is either off or brighter than normal, instead of flickering, and no video
hopefully that helps
Posted on May 01, 2008
Thank man
Posted on Jan 16, 2008
Check the memories if more than one check them one at a time
sometimes the memories cause this problem.If memories are working then check video card.
Posted on Jan 02, 2008
If it is a MSI mother board I was told not to put ddr 400 3200 memory on any msi mother board
Posted on Jan 01, 2008
  • 90 Answers
Sorry, it doesn't seem like it is a problem that can be solved here. Sounds like time to go to the repair shop.
Posted on Dec 28, 2007
How to reset a emachine t6216
Look for RESET button switch inside of your computer then short it by using screw driver or any metal that can short the switch.
Nov 15, 2010 | Computers & Internet
Emachine t6216 will not boot, fans stay on high and thats it. I do not hear hard drive spinning. It shut down a couple times while in use before this and came back on. also, it did not boot before and did...
hi Rpbarnhart.
this could be a few things wrong here.
the first thing i would get checked is the power supply.
Most likely either Motherboard or the CPU. Does this have a graphics card or built-in.
Standard procedure is to:
Clear the CMOS - chk manual for procedure.
Disconnect all cables from all drives and test.
Pull RAM and try with one module at a time in slot 1. Then try 1 in what might be slot 3, the 1st slot of second pair of slots.
Before giving up, I'd pull all the drive cables at once. Even carefully mark the front case wiring and pull everything but power switch if you can. You really want to remove all complications that might be an issue. Take it down to PSU, motherboard power, cpu fan and RAM.
Ok, there is Good news, and bad news. FIRST the bad news. You are not getting any power to the CPU. Fans and lights indicate motherboard power, BUT, power supplies ALSO provide power straight to the CPU, and if the CPU is not getting powered properly, it will not function.
or you could check these links out if the above does not work for you.
https://it.toolbox.com/question/my-emachines-model-t6216-does-not-boot-into-bios-061810
Build PC Emachine will not boot up
https://forums.techguy.org/threads/emachine-wont-start-up.1198007
Dec 08, 2017 | Computers & Internet
Emachine T6216 onboard video is shot (nothing on known good monitor) Have installed new PCI-Ex16 graphics care. Need to disable onboard video. Is there a jumper on motherboard?
Have you tried entering BIOS? I beliveve that you have to press and hold F1 during boot to enter BIOS. Once in there you should be able to disable onboard video card.
Apr 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
What motherboard do i need foe emachine t6216
http://www.newegg.com/Product/Product.aspx?Item=N82E16813153052
I would still recommend calling emachines support to send you a replacement. Though the one above would also work just fine. Have a great day :)
Jun 11, 2009 | E-Machines eMachines Desktop PC
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
NO VIDEO
try changing the memory cards if any one slot got the problem, clean the slot area from the ram., reset bios conf., it works
Mar 26, 2009 | E-Machines T6216 (827103077834) PC Desktop
Emachine w3609
According to TigerDirect, this case has a side opening door. Here's a youtube video that even shows how to do it on an emachine computer.
Steven
Sep 17, 2008 | E-Machines eMachines Desktop PC
E machine T6216 won't connect to Internet anymore
Go in device manager and find the network card drivers rolback the drivers then restart PC if that is not wor rinstal the drivers
May 26, 2008 | E-Machines eMachines Desktop PC
I have a emachine t6216 when i turn my computer on the monitor say it can not display video
Did it work before, need more info to assist. os, any changes if it worked before?
May 25, 2008 | E-Machines Computers & Internet
E-Machines eMachines Desktop PC Logo
423 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
