Question about Frigidaire FTF530FS Front Load Washer
Error codes My washer dryer keeps coming up with e20 error code during the cycle of washing or drying i can't find a manual with the error codes, i have cleaned the filter so i know it can't be fluff. I would appreciate any suggestions or the error codes. Thanks Mostly getting e20, but every once in awhile e70. Seems to be using only hot water, having trouble draining...water does not spin out so clothes are sopping wet. We have an old house and husband tried to make sure pipe was not clogged because disposal was dumping waste I guess where the washer drains, but now the washer refuses to finish. You can open the door when e20 appears, but it shows up as the error again every 5 to 10 minutes it seems. Have not found a clog or kink in the hose yet, etc. What can I do...don't want to get a repair person when I think my washer is fine just trying to tell me what needs to be changed.
You need to clean the hoses that go to the water pump
Posted on Mar 27, 2009
    President:
  • 1,294 Answers
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Posted on Dec 28, 2007
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Error code 20
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Sep 04, 2006 | Zanussi ZJD1219 Front Load Washer / Dryer
Frigidaire FTF530FS Front Load Washer Logo
409 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
