The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used: - Run the unit through a Rinse/Spin cycle. - Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). 4. Check/clean drain pump filter of foreign objects. 5. Plug in washer or reconnect power. 6. Check drain pump. 7. Check the pressure switch. 8. Verify CCU operation by running a Diagnostic test or any cycle.
(If the suds error code continues to illuminate after the above inspections are preformed, replace the pump.)
My Maytag neptune washer door is locked, and will not open. Have turned the washer off, unplugged it...
(More)
My Maytag neptune washer door is locked, and will not open. Have turned the washer off, unplugged it and it still will not unlock. Any suggestions?
maytag lat9606age top loader sometimes won't spin, instead it will agitate. motor seems to run the...
(More)
maytag lat9606age top loader sometimes won't spin, instead it will agitate. motor seems to run the wrong direction. When skipping straight to the spin cycle same thing happens it will only agitate. other times the full cycle will work no worries.
We have a Matag Neptune washer - model # MAH4000AWW - -It is about 10 years old. When we do the...
(More)
We have a Matag Neptune washer - model # MAH4000AWW - -It is about 10 years old. When we do the very first load of laundry it make a grinding noise like when the timer moves and it does this when the tub moves back and forth. Again - it only does it on the first load.
I have a MAH4000AWW and it starts and stops in mid cycle and sometimes it drains and sometimes it...
(More)
I have a MAH4000AWW and it starts and stops in mid cycle and sometimes it drains and sometimes it spins. Any recomendations? Greg
Hello, I have a 12 year old Neptune front loader makes a short buzz sound when washing right before...
(More)
Hello, I have a 12 year old Neptune front loader makes a short buzz sound when washing right before the tub starts to move. In this unit, when its washing, the tub starts and stops many times during the wash cycle which is normal. But before its time to start the tub there is a quick bzzt sound and then then tub starts moving. It's done this for a long time and now it is getting worse. Any idea what this sound is and what I would need to do to fix it? Much thanks in advance!
