Question about HP P1100 21" CRT Monitor
Compaq p1100 I have 11 horizontal lines greenish in color on my monitor the color over is kinda faint and when I push the button on the farthest left the screen goes off and when the screen comes back the color is vibrant only for a second. Thank you Jeff
  • 54 Answers
SOURCE: LCD monitor comes on for about 10 seconds then goes off
It sounds like the power supply board on the monitor may be faulty (that or the backlight).
You could test it on another computer to see if does the same thing (or another monitor on your computer).
If the same problem occurs on this LCD you'll either need to get it repaired under warranty, or pay for it to be repaired. Or just throw it out.
Posted on Dec 09, 2008
  • 4 Answers
SOURCE: HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Posted on Feb 19, 2009
  • 66 Answers
SOURCE: After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
Posted on Apr 09, 2009
  • 417 Answers
SOURCE: HPW2338h goes black after about 3 seconds. Push
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
Posted on Dec 15, 2009
  • 1121 Answers
SOURCE: screen goes black after 5 to 10 minutes of
there is a screen light board defective as inverter board. there are on the market, some inverter boards available to LCD Monitor, Check for diemen Company on this site:
Posted on Dec 23, 2009
  • 109 Answers
SOURCE: monitor goes black
problem with ccfl lamps, inverter circuit or powersupply circuit...
Posted on May 17, 2010
0 characters
1 Points
How to reduce greenish colour on hp 1702
in the main menu of your display buttons on your monitor there is color settings red blue and green wshere you copuld adjust. it this helps please rate with comment
Feb 06, 2013 | HP Compaq 1701 17" LCD Monitor
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computer Monitors
My compaq 7540 monitor settings menu automatically opens frequently and on the other side of the monitor means on the upper right corner of the monitor the color slightly greenish
about the settings menu it is the problem of the main system ic in the monitor.And about the colour on the right side corner pls change the ptc in the monitor .
Jul 21, 2009 | Compaq CV 7500 17" CRT Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computer Monitors
Horizontal lines dark background Problem - Compaq FS7600 17" Flat-Glass Monitor
1 it is generally due to poor focusing. 2 check crt base for loose or focus control wire loose. 3 if monitor is very old then crt might be weak. good luck.
Oct 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Nov 01, 2006 | LaCie Electron 19" CRT Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
HP P1100 21" CRT Monitor Logo
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
