Tony M Hi a G3 mac running 10.3.9 will apparently not see an Iomega external USB drive (160Gb) What can I do???
  • 34 Answers
Get windows. If it doesnt recognise a device, it will go online and get what it needs for that device. As for macs however, your screwed.
Posted on Feb 24, 2008
A USER GUIDE FOR LPHD160-U
Hi Lorrie -
I think you'll find the document at the link below to be of use. First off, it starts out like no more than a list of where to get help from - but several pages into the document it does go into actual USAGE instructions, covering use, formatting, connection, and so forth. Within the document there are also links to other Iomega online resources about troubleshooting drives and so forth. See if this helps:
http://www.sb.fsu.edu/~xray/Manuals/Iomega-EHD.pdfhttp://www.sb.fsu.edu/~xray/Manuals/Iomega-EHD.pdf
Oct 28, 2016 | Iomega Media Xporter Lphd160 u 160gb Usb...
Iomega Portable hard disk service center in kerala
Look for the warranty center for Iomega, I did a quick google and found Accel the company to provide warranty. Look for their branches.
Nov 02, 2012 | Iomega Media Xporter Lphd up 160gb Usb 2.0...
I have Iomega external desk hard drive 160gb silver edition series I install windows 7 pro. When I tried to install the software it would not install. message states that this product does not work with...
Hi jtenu2,
The reason why you're getting the error message "product does not work with this operating system", is because the software is not compatible with your operating system. The easiest way to solve this error is to check if you're running a 32 or 64 bit operating system. Just right click on my computer then select properties and it will show you the details of your system. If you're using a 64 bit operating system you also need to install a 64 bit software on it.
Hope it helps.
Thank you for using FixYa.
Apr 05, 2011 | Iomega Silver Series External 250GB...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
I just bought an iOmega eGo 160GB external hard drive and have no idea how to use it once I've installed the program. Help!!
From what I'm finding; this drive is a USB 2.0 drive. First, you'll need to plug the drive into the computer via the supplied USB cable (if it came with one) and any AC power for the drive if it requires it.
Then, your PC should detect it and you then need to run the software for it to be configured properly.
To use the drive, simply (if in windows) double click my computer and the drive will probably come up with a name such as eGo or iOmega Hard Disk or possibly even External Hard Disk. From there, double click that drive and start copy files! :)
Sep 11, 2008 | Computers & Internet
Failure to read USB connected storage drives
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Jul 26, 2008 | Apple iBook G3 Mac Notebook
External drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Iomega 33089 250 GB Hard Drive
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
