Question about Philips 28PW6506 28" TV
Philips 28PW6506 28" TV - no picture - just went pop
The TV was on and then large pop sound, a small puff of smoke and the machine went off - red light stayed on but nothing else. Any suggestions or is it terminal? Thanks
    Problem Solver:
  • 12 Answers
Please check TV's control board main capacitor for worn out.
Thank you.
Posted on Dec 28, 2007
I have a Samsung PN51E530A3FZXA 51" plasma TV. I heard a pop & saw smoke from left rear of TV. TV went black & had no picture or sound, however the red power light stayed on.
Unfortunately plasma tvs are a lot more complex to service, instead of 2 or 3 boards there are a half dozen at least. I would guess when the main PS board went out it took some other boards with it. I don't have a manual for your set but I would look at the power supply sub boards, there generally are 2 of them, or on some models that is parts of the other boards. Generally there is a legend to see what voltages are supposed to be present at what places, samsung is good about making the test points on the boards. Also there are fuses on most the other boards and its possible one of those has blow, it won't be a typical fuse like your used to seeing, some are a small green component and some are white mini fuses...Good luck!
Nov 10, 2017 | Samsung Televison & Video
I have a 77 corvette stingray, a wire on starter came loose and caused small puff of smoke from arching, i lost power everywhere . wire harness was "modified" aparently when prior owner swapped motors....
The starter should have one large battery connection , one small red or purple wire that connects to a blade type connection on solenoid . Take a jumper wire from large connection , battery , and touch blade connection on solenoid to check....
Nov 18, 2017 | Chevrolet Cars & Trucks
TV went puff, completly blank a little smoke and a
Probably going to cost more than a new one is worth, and then you have still got a "Fixed" unit & in my experience once things start to fail there often is a domino effect. Still if you can get a free "Quote" for a fix, get one and see?
Jan 27, 2010 | Televison & Video
Power board is dead,know how to solders?Replaced those capacitors that puff up or burst open.Or buy a whole refurbish power board at,
Jan 26, 2010 | Hitachi 60UX58B 60" Rear Projection...
Bike will turnover but not start. It happened at
Sounds like either you coil went bad, the ignition module...or a wire shorted out
Aug 27, 2009 | 2005 Buell Blast
The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Dec 28, 2008 | Kitchen Ranges
Thermal Arc Welder 150 GTSW went ''pop''
You badly need a service manual, you might be able to get one at the Thermal Arc home page.
Since it blew the input power breaker and let off a bit of smoke we'll take as given that something in there shorted. Inverter welders like this have a rectifier section, then an inverter section, then another rectifier section before the torch. I'd bet a little money that what went pop was one or more of the SCRs in the rectifier section. You really need the manual to do anything useful to this machine, pay particular attention to the repair sections where they talk about cold checks before powering the machine on again, it'll save you hours of replacing parts.
Please rate my answer,
Nov 15, 2008 | Welding Tools
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Philips 28PW6506 28" TV Logo
242 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
