Question about Olympus FE-120 Digital Camera
Flash mode locked to Off
Pressing the flash mode button on back of camera the menu comes up showing that the flash is set to off. Using the up/down arrows (as defined in handbook) the menu changes to another mode, leaving flash set to off.
Help. The camera is 12 months old and only used occasionally.
  • rohloff Dec 22, 2008
    I have the same problem. The only way the flash will go is when I select night scene.
Try this, I had the same problem. Here is what I did, I powered off the camera then with the menu button pressed I turned the camera on. This must set the camera back to default settings. I was then able to turn my flash to auto or any other selection.
Posted on Dec 22, 2008
Canon 60d internal flash
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
SB-800 Stuck in REMOTE
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Why does "raise the flash" come on the screen when I turn my coolpix s5090 camera?
I do not know allot about the s5090, but I can give you general information based on how most Nikon pocket cameras are designed to work. If the Nikon is set to one of the automatic modes it is designed to prevent you from taking a picture if it senses that there is insufficient light to get a properly exposed picture. The camera may be telling you to rase the flash because it needs more light. Also, somewhere on your camera there is probably a menu that allows you to choose the flash mode. It may be in your regular menus or, if your camera has a round left-righ-up-down switch on the back, you can select the flash mode by pushing up and then using the right-left keys to choose the flash mode. The mode you select is locked in when you push the button in the center. In general, the modes are automatic (the camera decides when flash is needed), red eye reduction (the flash activates twice; once to cause your subjects eye's iris to close and the second to take the picture), flash always (flashes regardless of the ambient light) and flash off.
Jul 12, 2014 | Nikon COOLPIX Cameras
Flash stopped working
The flash in the Camera can be enabled to Flash Forced ON by pressing the Up Arrow control button on the Camera. Press the button continuously to select the desired settings.
Make sure that the Camera Mode (REC MODE) is not set to Burst or Multi Burst.
Flash will not work when the Camera is set to ISO High Sensitivity mode or Twilight mode in the Scene Selection.
The flash will not work in Movie Mode also.
When using the Landscape, snow or Beach mode, set the Scene Selection to Flash Forced On.
This should resolve the issue.
Thanks for using FixYa.
We wish you a Happy Holiday Season!!
Dec 26, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Cant get flash option to come back on sony dsc-t70?
So I went to Menu, Record Mode, then turned off the Shoot Continuously Mode/Burst and they flash options came back!!! So glad, this was driving me crazy
Nov 22, 2009 | Sony DSC-T70 Digital Camera
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
My pictures turn out fuzzy all the time and i can't figure out how to turn on my flash. Please Help! Casio Exilim EX-Z70
Flash should turn on by pressing the "Set" button and then the down arrow until you get to the flash menu. Choose the setting that looks like a lightning bolt.
If that doesn't work press the "Menu" button and then press the "right arrow" until you are on the far right tab. Press the "up arrow" until you come to "Reset." Press the "Right arrow." The camera will ask you if you want to reset it. Tell it "Yes." This will take it back to factory settings and clear any mode that turns the flash off.
Are the pictures fuzzy because the flash isn't working? Are outdoor pictures in daylight fuzzy or OK? If they are fuzzy all the time you may have a lens problem. If they are only fuzzy when the flash is needed, fixing your flash should cure the problem.
Dec 18, 2008 | Cameras
Using a speedlight sb800 off camera on a Nikon d80
Found a great website that explains this since it's not in any of the manuals or other websites I have searched for so long!
This covers the D70 and SB-600 which I use personally. It should be similar on other cameras. Any questions? Presuming you have USA equipment, call (800) NIKON-UX for details.
On your D300:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Flash cntrl for Built-in Flash
Move right and down to: C Commander Mode
On your D70:
Use P, S, A or M exposure mode.
Press MENU. Go to the yellow wrench menu, and be sure CSM MENU is set to DETAILED. Otherwise you won't see the next setting!
Go to the CSM menu which looks like a purple pencil. Set #19, Flash Mode, to "COMMANDER MODE." Further click to the right to set the commander mode to "TTL."
You also may set the commander mode to Manual or AA, which are other modes to fire the remote flash. The SB-600 only works with TTL and Manual. You set the manual power level at the camera.
Don't forget to POP UP THE BUILT-IN FLASH!
On your D200:
Press MENU.
Move right and down to: e3: Built-in Flash
Move right to get to a confusing panel of C Commander Mode settings.
Once in this confusing panel you can set everything for two external groups of flashes and the built-in flash. You move between the different fields by moving left and right, and set any field by toggling up and down.
In this panel you must select Channel, and set it to 3. Default is 1, which is the default for the SB-800. Don't ask me why they are different. Default for the SB-600 flash is channel 3, so if you forget this it won't work! Sorry about the complexity; Nikon didn't ask me for help here.
This is such a pain I use one of the D200's setting banks to store this.
On your SB-600:
Hold down ZOOM and "-" together to enter the CSM settings. That's why you see a gray "CSM" marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z-shaped arrow. This arrow refers to wireless communication between the flash and camera. When you see the wiggly arrow, press MODE to make it say ON.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
Presuming you did this correctly you'll see "CHannel 3" and "GROUP A" displayed. If you see different channels or groups then press MODE to get one or the other to flash and then the + or - buttons to set them back to 3 and A. No, I have no idea why these are the settings you have to use instead of 1 and A; 3 and A are what you need to talk to the D70's built in flash. If you get smart and choose others then it won't work. The other channels and groups are for people much smarter than I who want to try to rig up a zillion flashes to work together and control them all separately and remotely. I prefer professional studio strobes if I'm using more than one strobe at a time.
The SB-600 doesn't go into standby in this mode, so you can run down your batteries if you forget and leave it this way. It just sits there blinking its little red LEDs visible from the front.
Easy, just shoot! If you set everything to TTL as I suggest then the camera just does everything. You and I are free to concentrate on the more important parts of making a great image.
Everything is controlled from your camera. This is very convenient if you have the strobes someplace remote, like duct taped behind plants.
You can control the remote flash's output simply by varying the flash exposure compensation control on the camera. You can do that without taking your eye away from the finder! You do that by pressing the same button you used to pop up the flash and then moving the front control wheel. You'll see the amount of compensation on both the camera's top LCD as well as through the finder. Brilliant! You can add more or less flash fill without having to walk over to the remote flash.
You can set the mode (TTL, Manual or AA) from the camera.
You can set the manual power level from the camera as well.
Try to have the little black window on the bottom right of the flash (marked with that same wiggly arrow) pointing in the general direction of the camera. Thankfully it's not a big deal; you don't even need a line of sight so long as the flash is anywhere near the camera or subject.
The sensor is sensitive enough to pick up the flash from the camera even if it has to bounce around a corner or off the subject. This makes this current system so much better than the older ones. You can hide flashes anyplace and even if they can't see the camera they usually go off correctly. They beep to let you know what's going on, even if you cant' see them.
The i-TTL system is much better than the old systems because it just works. If you ever used the older systems you'd know that half the time you'd get no flash, or a full-power flash that also wasted the shot. This new system just works, and that's critical for use in the field where the remote flash is rested on a garbage can or held in your left hand while you hold the camera with your right.
I even can have the flash in a different room out of view of the camera and it goes off just fine.
It works fine even 50 feet away. I haven't tried it any further. Honestly I have no need for a flash that far away; I was just seeing if it worked.
Jul 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Nov 16, 2007 | Nikon Speedlight SB-800 TTL Flash
About taking picture
u need to set your flash mode on auto mode u can by pressing flash button or u can press menu & selet reset and ok it
Jul 14, 2007 | Nikon COOLPIX S6 Digital Camera
Olympus FE-120 Digital Camera Logo
70 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
