Question about GE GSH25JFR Side by Side Refrigerator
Frig side by side problem
I own a side by side. The freezer is working and making ice, but the other side (fridge side) is not cooling. What can I do? And had a repairman replace two items the last time inside the freezer. Some kind of timer and I think heating thing this was two or three years ago. Could it have gone bad again?
  • Jeff23456 Feb 21, 2008
    thanks replaced element(burnt out), timer and some kind of thing that has 2 wires and clip to a pile in the back of freeezer.
  • 958 Answers
Yes it could. you again have a defrosting problem. do you noticed frost at the back side of the freezer section? the repairman could have replaced your heating element and your defost timer.
Posted on Feb 21, 2008
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
