What model do you have? If you press clean that wont defrost the unit. You can find this information at www.u-line.com and look under specifications and documentations.
The icemaker turns on fine, water runs through the system however the pan will not drain. I have...
(More)
The icemaker turns on fine, water runs through the system however the pan will not drain. I have confirmed no clogs. System eventually shuts off, displays P1 problem code.
the ice maker is running and the water is alson runing, however it doesn't get cold enough to make...
(More)
THE ICE MAKER IS RUNNING AND THE WATER IS ALSON RUNING, HOWEVER IT DOESN'T GET COLD ENOUGH TO MAKE ICE.
