Question about Sharp Viewcam VL-Z1U Mini DV Digital Camcorder
Smart VLWD450 camcorder
Just get a blank white screen when I turn the camcorder on whether to play or record. Any ideas?
VLWD450 camcorder, I can record and the vedio is on the screen. However, if I tried to playback and view it on the screen, nothing happened, black screen. Any idea? Thanks!
Posted on Aug 23, 2009
Casette compartment is not working. actually it opens but the casette is not coming out of that compartment. any solutions?
Posted on Jan 22, 2008
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sep 29, 2010 | Sony 8mm Stantard Grade 120 Minute...
My JVC-GRd72 camcord - error cap lens error when cap is NOT ON
Replace the CCD base Assy on the optical block assy.
Sep 27, 2009 | JVC GR-D30U Camcorder
Blue screen
In the playback mode, the screen is suppose to be blue, till you start the tape playing, but if you get the blue screen in the record mode, I have not idea how to help you. You should see what the camera lens see, when in record mode.
Apr 02, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Blank screen during playback
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
Aug 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Sharp Viewcam VL-Z1U Mini DV Digital Camcorder Questions
Sharp Viewcam VL-Z1U Mini DV Digital Camcorder Logo
89 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
