Question about Car Audio & Video
Hello can you help me i have 1998 mazda protege se my problem is in the last two mouths we have had some proplems with this car sqwelling replaced altenater replaced belts replaced emc module still have the prolem but now only on the take off or come to astop all so car sakes on idlea do i just need to re teyten the belt
I feel that it could be the tension pully. It holds the belt tight so it doesn't squeal while it goes around the other pullys. You said that on idle the car shakes...do you mean the engine shakes? If that is the case...the best suggestion is to check out the engine mounts an see if the rubber bushing(s) are gone. If they are ok...then I would bring it to my mechanic an ask them for a free diagnosis....an ask them how much it would cost an what is the problem. Hope that helps.
Posted on Jan 01, 2008
How do I replace the alternator belt on 1997 Mazda Protege?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem Mazda Protege 1994 1998 Repair Service Manual PDF
Oct 08, 2014 | 1997 Mazda Protege
MY AC DOESNT WORK ON HIGH SETTING ON 98 MAZDA PROTEGE
does it do the same if you put it on heat it could be the resistor
Feb 28, 2013 | 1998 Mazda Protege
Inside missing fuse box cover 1998 mazda protege lx
What does the fuze box actually look like? i found a diagram which you can see if it looks similar and if it is then it may just be for your car.
Mazda 1998 Protege Fusebox Diagram
Oct 20, 2012 | 1998 Mazda Protege
Hello... I have a 2000 Mazda Protege 1.6.c.c. I had the timing belt replaced, the car runs fine but now, whenever I stop the car shakes...??? I need some help...!
in park idleing does it shake is the check engine light on when is the last time you changed plugs and wires fuel filter
Dec 01, 2010 | 2003 Mazda Protege
Replace fuel filter on 2000 mazda protege
A 2001 Mazda Protege (actually, all models from 1999-2003 including the DX, LX, ES, Mazdaspeed, and Protege 5) does not have an inline fuel filter. The only fuel filter it has is a "strainer" or a "screen", which looks like a nylon mesh "sock". This strainer is connected to the fuel pump, located in the gas tank. Although this fuel strainer does not require periodic replacement, it is recommended that it be changed if you are replacing the fuel pump.
May 03, 2010 | 2000 Mazda Protege
What type of gas does the mazda protege se take
regular 87 octane unleaded is sufficient for this car. putting premium in is a waste of money and can actually hurt performance. the only exception to this can be if you life in an extremely low altitude area (below sea level), in which case you sometimes need a higher octane to compensate for air density.
Apr 10, 2010 | 2001 Mazda Protege
Where is horn located on 1998 mazda protege?
the horn is normly located at the front of the car behind the grill
Jan 15, 2009 | 1998 Mazda Protege
Car Audio & Video Logo
238 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
