Washing machine its not working all it keeps saying is 1 minute and spin/end thedoor locks but still nothing is happening.
  • raggs Dec 28, 2007
    please can you help me solve this problem. it probably is something simple but i can not figure it out many thanks raggs
My wm54does not run throuh cycle
Posted on Sep 04, 2010
Ha Ha , It was very simple and all you have to do is ............................hold the start button in until the timer reset's it's self. Which on a beko wma 765w washing machine the button look's like a play / pause button from a stereo...
Posted on Dec 29, 2007
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
I've recently bought a Hoover 800F New wave and I don't know how to open the door...can you help me please?
turn the wash temperature control knob anticlockwise until you come to the key symbol at the end of the blue zone; then turn the knob a little further and the door will swing open; a special safety device prevents thedoor from opening during the wash or at the end of the spin cycle; at the end of the spin wait up to two minutes before opening the door - the instructions from the user's manual. good luck!
May 17, 2011 | Hoover Washing Machines
Whirlpool Duet GHW9150P Front Load Washer how do I get the washer off the control lock
take off the front panel below thedoor. reach up behind the lock you will feel a little knob. pull it down about 1/4 inch and pull door open.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Neptune MAH5500B waon't spin - clothes very wet at end of cycle. Tried to just spin but no spin action and timer just goes down to 1 minute and stays there.
turn back to spin,
and see if you get a lock light,
if your lock is working you will need a new motor control,, and maybe a new motor
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Oct 10, 2009 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Washer spin and not enough water
Spinning both ways is pretty normal. You did not say if your clothes were clean in the end. You may not see much water when it washes, when it rinses you may see about 1/3 thru the glass. Careful with the door aft wash, wait for 2 minutes before opening.
Feb 28, 2009 | Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Won't spin fast.
sounds like motor control ..but three thing can keep it from not spinning .. Motor control- main control and or door lock... if just the spin cycle it may be the motor control..let me know what you find..
Aug 29, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
548 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
