Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Samsung syncmaster My son's lava lamp fell behind his desk and in the process banged up against the top of the monitor. Then his screen turned everything to a blueish cast. He can still read and see everything it's just tinted blue now. Is there a reset button on the monitor. He has a brand new computer and it appears the same with each CPU attached to it.
My samsung 730B moniter will not run how do I fix it?
Posted on Jan 11, 2008
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
The screen syncmaster 940b comes on momentarily and the fades out, if you turn the screen off then on it does the same thing.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 10, 2010 | Samsung SyncMaster 940BE 19" LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
SyncMaster 740N 17" LCD Monitor: I have two of the SyncMaster 740N's as security mo...
May 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
My samsung syncmaster 731b monitor screen turns off when i start up my system. I have to turn it on and off several times to get it to stay on .Do i need a new monitor. Harold
May 01, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
My Samsung Syncmaster 204B has a dark screen when I turn it on. It slowly "warms up" to it's usual picture quality, but the warm up is taking longer. Thoughts?
Please read below if you decide to DIY repair.
Apr 19, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My Samsung Syncmaster 245bw LCD displays a blank screen.
wardysbiz, I should think SAMSUNG would ship you a replacement unit. It might be what is called a REFURBISHED unit of same model.
In future try not to use the word BROKEN. I thought an elephant stepped on it, or it fell from a great height. Try "nonfunctional" or "inoperative", "has failed" , "never worked" "out of box failure" "Dead on arrival unit" Also contact NEWEGG and ask lots of questions about quality and reliabilty of lcd monitors. Find Your sales receipt or card statement to prove pop. Don't let them off the hook!! I would think turn-around process to be about 14-20 days. 12fixlouie
Dec 10, 2009 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
177 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
