Question about Samsung V20 XVC 2400 Notebook
Blank screen, greyish/white
The power is on and there is backlight but no features.
Hi, i have the same problem. I have no back light but when i shine a light on it i get coloured lines instead of the nomal windows loading, or the bos
Posted on Feb 05, 2008
    Scholar:
  • 111 Answers
Could you explain more in detail what the problem is, what laptop do you have?
Thanks
Posted on Dec 28, 2007
How do I get my LED TV to start working?
depending on the model, if the backlight has come on but nothing else then the main av board has fun into a fault, some models have a rest sequence to use on the original tv remote to reset to factory settings, if your model does not have this feature, then turn the power off for 10 min and plug power on and holding down the either of these, power button or menu and select. some times these work to reboot.
May 19, 2017 | Televison & Video
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
What is opc light on my sharp aquos tv
This can be called Optical picture control and it adjust to suit the room light.
Please read the text below"
Dynamic Backlight Control - One of the nice features of the Sharp AQUOS LC-32D6U is what Sharp calls OPC, a name they use for their dynamic backlight control. You might also see this feature referred to as a dynamic iris on other LCD HDTVs or disguised under some proprietary name, but fundamentally the principle is the same. Its primary function is to try and maintain a high Full On/Off contrast measures the ratio of the light output of an all white image (full on) and the light output of an all black (full off) image. 2) ANSI contrast is measured with a pattern of 16 alternating black and white rectangles. The average light output from the white rectangles is divided by the average light output of the black rectangles to determine the ANSI contrast ratio. When comparing the contrast ratio of video devices make sure you are comparing the same type of contrast. Full On/Off contrast will always be a larger number than ANSI contrast for the same video device.">contrast ratio under any lighting condition. So when room lights come on or off or the sun enters the room, with OPC enabled, the backlight in the LCD will dim or brighten depending on the amount of light in the room. This is managed by a light sensor located on the front of the unit. When OPC is enabled there can be a slight reduction in the dynamic range of the display as the display attempts to maintain contrast and color saturation as room light changes. We had a chance to compare this feature with another LCD HDTV that was of comparable size but without dynamic backlight control, and the Sharp AQUOS LC-32D6U with OPC enabled was the clear preference.
Jan 24, 2011 | Sharp Televison & Video
Where can I find instructions for replacement of the backlight inverter?
It's hard to find a step by step instruction on how to replace a busted backlight because of different model concerns.
If somehow you manage to get through on your lcd mainframe with careful disassembly of the back cover.. then you should watch this. A 2 part recorded video on how to remove a backlight inverter for a laptop. And a video on how to Install a laptop inverter here are the 3 links:
1. http://www.youtube.com/watch?v=xff-ztgAXlw&feature=related
2. http://www.youtube.com/watch?v=J9sv_tEjong&feature=related
3. http://www.youtube.com/watch?v=6lJhZPHN5iU&feature=related
Hope you learn watching.
Much appreciated if you rate this help.. thanks
May 21, 2010 | Toshiba Satellite A205-S5812 Notebook
Picture goes dark on different sections of screen intermitently then its ok for a while
Intermittent backlight lamps or backlight inverters.
If this model has an auto-dimming feature, try disabling that feature.
Oct 20, 2009 | Samsung LA46A550 46 in. HD-Ready LCD TV
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
Help! Power saving feature shutting me down
There is not a way - sorry - the only adjustable is the backlight feature
May 30, 2008 | Verge DFP-200 MP3 Player
Backlight only comes on when the power button is pushed
It doesn't sound like you're doing anything wrong. It sounds like that is the way the unit was designed. It's a power save feature.
Can you see the time on the screen if the room light is on? If not, the backlight won't do you any good anyway.
Unless there is some sort of menu that allows you to change it, you're probbaly stuck with the way it is. It's all in the software thats programmed into the microprocessor and that's almost impossible to modify.
The only thing I could think of is to find the backlight voltage line and power it directly off of the power supply (using isolation diodes), keeping it on all the time. This however requires you to take the unit apart and dive into the electronics - something you may not wish to do.
- Jim
Feb 12, 2008 | Fisher SLIM-1500 CD Shelf System
Samsung V20 XVC 2400 Notebook Logo
65 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
