Question about Hotpoint Aquarius WF000 Front Load Washer
Belt fitting for a WF000 hotpoint washer?
Havea Hotpoint WF000 washing machine belt came off have replaced belt but keeps slipping off , belt is tight when on unsure if fitted it right should belt go round two or three things as I am fitting it on only two
    President:
  • 1,294 Answers
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Posted on Dec 28, 2007
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
The belt on the drum keeps slipping off,what is wrong with it.thanks
Hi, W/D here.
Here's a few things to check:
1. Is the tensioner pulley engaging the belt and holding it tight?
2. Is the belt worn out?
The belt would be most likely to me. If it is old or obviously worn, replace it. Once the belt is on the drum, motor and tensioner pulley. rotate the drum by hand several revolutions, slowly (with the power off) to seat the belt back into it's tracking position.
Best regards, --W/D--
Jan 28, 2011 | Hotpoint Aquarius WF000 Front Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
Please rate my solution.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How to fit a belt to a wf440p washing maching
remove the top cover and lower rear cover. loop the belt over the motor shaft and then around the drum pulley, this will probably only go round halfway as it is tight, hold the belt to the pulley by turning it rather like putting on a bicycle chain.
when it's on make sure it runs centrally round the pulley adjusting the position on the motor shaft if needed.
Jan 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoit belt
Feb 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
361 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
