Check to see if the pump is leaking some where.Then clean the pump out if there is no leak.Are you burning kerosine?K 1 will give you no problems,but diesel will cause a lot of problems,some reddy heaters can burn both,and some you can not,so look at the warnings.
Reddy Heater 55,000. Runs & cuts off while it's still cold. By passed thermostat. Still...
(More)
Reddy Heater 55,000. Runs & cuts off while it's still cold. By passed thermostat. Still same. Motor not overheating. Can you help?
I have a Reddy heater model RH 10 PT. I can light the pilot light but when I turn up the dial the...
(More)
I have a Reddy heater model RH 10 PT. I can light the pilot light but when I turn up the dial the pilot goes down and the heater goes out, any suggestions?
