Vtech Two Line Digital Answering Machine Phone
Problem for Vtech Two Line Digital Answering Machine Phone
I left my Vtech phone
By ryho on Oct 17, 2009
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me, but don't know how to remotely activate my phone. Can you help? I use SKYPE to call in.
Comments:
Oct 17, 2009
- I'm sorry but your suggestions don't apply to my problem. When I dial my number, after several rings a you hear a message: "I'm sorry but the owner of this number did not activate the answering service. Good bye". Afterwords the line gets disconnected.
Oct 17, 2009
- I just sent you my response to your recommendation and I'm not sure if it went through.
None of you suggestions work in my case. After a number of rings you hear a voice:
"Sorry, but the owner of this number did not activate the answering service". Then it immediately hangs up the phone.
Oct 17, 2009
- I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me, but don't know how to remotely activate my phone. Can you help? I use SKYPE to call in.
Comments:
Oct 17, 2009
- When I dial my number, after several rings a you hear a message: "I'm sorry but the owner of this number did not activate the answering service. Good bye". Afterwords the line gets disconnected.
Oct 18, 2009
- After several rings I hear a recording "I'm sorry, please call later" and a hang up click. During the announcement I enter my PIN # but my answering machine won' turn on.
Solution #1
posted on Oct 18, 2009
Somewhat Helpful)
Murphybanton
Rank: Guru  Phones & Accessories  Expert
Rating: 90%, 2282 votes
Accept this the mail me on onifadeadewunmi@hotmail.com.
I will forward a document attchment to your inbox.
Cheers.
Remember to make a testimonial.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
michael34
Rating: 95%, 468 votes
You didnt leave the model number for the phone but I do believe they are pretty much the same when it comes to remotely activating the phone. Here is the instructions for the V-Tech V2656 cordless telephone. Click on the link: http://www.scribd.com/doc/5987025/v2656-Manual-vtech-phone-instructions and scroll to page 34
1.Dial your phone number
2.When the system answers, enter your remote access code (pin #)
T3.he system will beep once and tell you the number of new messages you have saved
4.Press 5 to access the voice command menu
5.Press 0 when you are finished
Note:
If you want to record your personal voice as the greeting press *7 and then #5 to stop it
Was this helpful?
Yes
No
Solution #3
posted on Oct 17, 2009
Somewhat Helpful)
lyzmorato
Rating: 85%, 220 votes
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Was this helpful?
Yes
No
Popular Solutions for Vtech Two Line Digital
Questions and Unsolved Problems for Vtech Two Line Digital
Do you recommend Vtech Two Line Digital Answering Machine Phone?
Answer
Answer
I got a call from 0402770156 I want to know whose number is
Answer
I have a 20-2481 2 Line cordless phone - One of the handsets does not charge anymore - I took the... (More)
Answer
Tried resetting dial mode to pulse; was able to break through dial tone for one day; back to not... (More)
Answer
We thought the problem was with the dial mode selection, so changed it to pulse. The phone worked... (More)
Answer
is there a battery that needs replacing for the answering machine even both phones work fine. Could... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phones Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
