Dear Sirs
I have a monitor that has a fault that the back light tube doe's not light
When the screen is looked at with a torch light the information is there
So do you know whare I can get a manual for this LCD monitor
-   Viewonic VG150m (white)
I obtained this monitr through an old employer and he said the screen has stuff in the background, but the backlight doesnt turn on.
I need some kind of manual for it or at least a website that will.
Thanks in advance-   gigawiz
Not too many manufacturers are providing schematic for their product. But you probably can try eservice.com if they have. you have to sign up to download. You did not mention the model of your manitor. However, if your monitor is old enough, it probably needs CCFL replacement. The ends of the tube usually get blacken when out just like the ordinary flourescent lamp. If still new, then it could be the CCFL driver (pwr supply).
i will be doing something and my screen will flicker then it goes black What can I do to fix it? ...
(More)
i will be doing something and my screen will flicker then it goes black What can I do to fix it? Thank you.
My Viewsonic VP213wb would flash a picture and then go black a few times on resume from the...
(More)
My Viewsonic VP213wb would flash a picture and then go black a few times on resume from the screensaver or when the monitor was turned off by software. It would eventually display a picture and work fine, until the next resume. However, this morning it flashed a few times and just stayed black. No power lights are on. The computer clearly thinks there's a monitor, since it continues to treat it as my primary display, but nothing is showing. Help! This is the second of these two do this in as many months.
