Trendware TRENDnet TE100-P1U Print Server
Problem for Trendware TRENDnet TE100-P1U Print Server
Problems printing using epson stylus dx4050
By CLOCKMENDER on Dec 28, 2007
it keeps saying photos printed.but printer doesnt print
Best Solution
posted on Jan 01, 2008
Helpful)
spinal
Rank: Guru
Rating: 90%, 258 votes
Hello CLOCKMENDER and Happy New Year. It is extremely difficult to provided decent advice from long distance .1st of all I get the sense that from your title(CLOCKMENDER) that you are far more intelligent than the average bear. So I will assume that if I give you the appropriate data you can run with the ball as you always have. If I understand you properly you have a situation where you not only send the appropriate commands for your computer to print a photographic image but you are receiving a response that "photos being printed". Typically that means this means that communication has been successful and that the "data (photo) has been successfully been transmitted and accumulated (recieved) somewhere. The response you are getting that "photos being printed " can occur if for some reason that data is being pointed to a "print folder". Think about it{and I am not being a smartass} , usually if a print job of any type cannot be successfully accomplished you will get a "nag" response of some type saying "uh oh....no good" .I must assume that you are not getting a printer error that appears in the lower right of your your taskbar. If most of my assumptions are correct then please consider the data I have provided and let me know how I might help if you wish it. I truly want to help. !! Listening.....
Was this helpful?
Yes
No
Solution #2
posted on Dec 29, 2007
Helpful)
ACT1850
Rank: Guide
Rating: 92%, 10 votes
Clockmender;
what type of print server do you have and what model of Epson printer do you have? I would check the memeory of the print server / if it is set to a static IP address / is it internal or external./ and than try printing the pictures in a smaller size to see if they pirnt at all. If at all possible try to set with a static and not let the network put a unc address in for the port. Try hooking the pirnter driectly to your computer and print. This will tell you if your memory in the printer will take that size of print.
Was this helpful?
Yes
No
Solution #3
posted on May 10, 2008
Not Rated)
scot341
Rank: Apprentice
Rating: 97%, 3 votes
this may be a dumb question but is the right printer selected on the network? The driver may be accepting the communication but not necessarily be ouputing to where you want.
Was this helpful?
Yes
No
Solution #4
Not Rated)
sapperj
Rank: Wiz
Rating: 83%, 55 votes
Has it ever worked or is this a new install? Models of 2 devices?
Was this helpful?
Yes
No
Popular Solutions for Trendware TRENDnet TE100-P1U
Questions and Unsolved Problems for Trendware TRENDnet TE100-P1U
Do you recommend Trendware TRENDnet TE100-P1U Print Server?
Answer
Answer
I can't print from any of my pc's on my router except the test file in the PS-utility. I also cannot... (More)
Answer
I've connected my trendnet on a LAN via a switch. The LED light is on on the trendnet and it's... (More)
Answer
I have the same problem. My laserjet 1018 appears offline in the trendnet TE100-P1U and... (More)
Answer
The utilities that came with the print server install OK, but get an error when attempting to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Trendware TRENDnet TE100-P1U...:
Top Print Server Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Print Server Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
