Question about Frigidaire GLTF2940ES Front Load Washer
I purchased my washer 8/05. The bellows in moldy and smells. Water continuously stays in the bellows. My wash load smells. I have run bleach and also vinegar thru a wash and it still smells....horrible. I have tried washing & drying the inside of the bellows with cleaning solutions and nothnig works. Black mold is on the outside of the bellows, right inside the washer door. It is getting to the point I cannot use the washer because the clothes smell worse when coming out than when going in.
I would appreciate ANY help with this problem.
I purchased the 5-year warrant.
  • ringsmuth Dec 30, 2007
    I use that type of detergent. That doesn't even come close.
    Thanks anyway.
  • Anonymous Apr 25, 2009
    My washing machine smells like mold. I have tried running bleach through it. I used Tide HE detergent. Do not know what to do.
Use Affresh. It is a tablet that you put into your washer and run it alone. You can buy it where you buy your front load washers. I bought it at Best Buy. hope this helps
Posted on May 18, 2009
  • 4 Answers
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Posted on Dec 29, 2007
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Describe your Frigidaire GLTF2940FE1 Front Load
Run a cycle with just bleach and detergent, no clothes.
Mar 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Fridgidaire front end washer
ok first of all, you should be using HE detergents, it uses less suds, regular detergent will slow your water from draining properly out of your washer. Another thing it is recommended that after you wash a load you dryer rubber gasket or leave door crack to dry out..
Sep 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Is there ANY way to remove the gasket from a frigidaire GLTF2940ES front load washer???? It is absolutely covered with mold, it is moldy underneath, my clothes smell disgusting!!! I want to clean...
yes there is way
How to remove and replace the drum gasket on the Frigidaire -Front Load Washer with notes on tub bearing replacement and inner drum replacement....
for all the detailed instructions
click the link directly
http://www.applianceaid.com/417_Frigidaire_washer.html
hope this helps
May 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDAIRE WASHING MACHINE MOLDY BELLOWS
I have used www.smellywasher.com with good results
Sep 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Mold/mildew
Run a cycle with or without clothes using a 1/4 cup of beach diluted with 3/4 cup of water...max out the auto bleach dispenser with this solution. After using, leave the door open to allow the water within to evaporate. We had the same problem and this was the fix.
Apr 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
362 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
