Question about Nokia 6080 Cellular Phone
Adding voice tag in nokia 6080
Dear Gurus,
I have 6080 mobile. when I try to add voice tag I get a error "Contacts not ready"
    Brigadier General:
  • 7,752 Answers
Have the phone flash that should corret the issues
Posted on Feb 21, 2008
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
Trying to ADD A CONTACT.
Yo! you can simply input the number as if you want to call it and use the OPTION to save it. You can as well go to CONTACTS on your menu and then ADD CONTACT to add a contact.
Jul 25, 2011 | Nokia 6080 Cellular Phone
Nokia 6080 phone restricted code
Get the Nokia 6080 Restriction Unlock code at
http://www.wickedunlock.com/ and Unlock it.
Oct 29, 2010 | Nokia 6080 Cellular Phone
Assist me with the restriction code for nokia 6080356258012101105
For the best unlock code for your Nokia model mobile,
you can try this site http://www.onlinegsmunlock.com/nokia-6080/rs7wp9/
It has the step by step instructions and easy methods for unlocking your nokia mobile phones...........
I forgot the password for my nokia 6080 pls help me open it . thanks
Below are tips on how to reset your Nokia Mobile phones:
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard Reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
Note
To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
on/off + * + 3
Before making a Hard reset better backup all your important information: contacts , memo...etc
Dec 29, 2009 | Nokia 6080 Cellular Phone
How do I activate the voice dial on my Nokia 6230i please?
At the menu screen,select menu and scroll down to contacts, hit select,then select names, find the number you want to add voice dial to, select details,select options,scroll down to "add voice tag" Hit select and follow the instructions.
One tip: when you program the voice call, you should be in the enviroment thet you usually use the voice dial. If you set it up in a quite place like your home and then try to use voice dial in a noisy place, it probably will not work. Also talking louder does not help.
Hope that helps. If not, you probably have a problem with the phone itself.
Latre....
Sep 22, 2009 | Nokia 6230i Cellular Phone
Technical problem
r u instaled nokia pc suit software to ur pc? if u not installed first install that software, than u will try..u all ready installed that software check ur mobile internet connection...
Aug 14, 2008 | Nokia 6080 Cellular Phone
How do i add voice tags to my contacts?
if it a nokia u go in ya phone book selct options and scroll down to add voice tag
Aug 13, 2008 | Samsung Cell Phones
Voice System Error.....
If you made a backup before try restoring one back.
If not;
  1. Do this regularly as this is an easy way to stay away from problems.
  2. Make a backup right now and format your phone by keeping pressed *,3,call key (green one) while turning it on.
  3. See if the problem is solved OR ELSE RESTORE THE BACKUP BACK.
BACKUP AND RESTORE:
It can be done from memory right there in Extras or Tools folder.
Rate if Satisfied!
Dec 17, 2007 | Nokia 6600
Nokia 6080 Cellular Phone Logo
60 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
