Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
REPAIRS AGENTLY NEEDED
CASSETT HOLDER IS JAMMED IN AN OUTSIDE POSITION
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 01, 2008
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
How to get a stuck tape out ,cassett player
You might have to take it apart to do that.
Apr 15, 2015 | Audio Players & Recorders
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
I tried to change the position of the zipper foot and ended up breaking the needle and now the bobbin thread keeps snapping when I try to sew. What should I do to fix this problem?
There could be a couple of general reasons for this to happen.
First, the tension in the bobbin holder could have tightened when you were trying to fix the needle. I don't explain them, I just know strange things happen when you try to fix one thing.
Secondly, I can't tell how old your machine it, but I know that the mechanism that holds the bobbin holder can become jammed and the thread wound around it. That too will cause the bobbin to not feed properly. You need to be sure the area around the bobbin holder is clear of all threads.
How did you try to change the position of the zipper foot? Did you just change the needle position and move the foot to the other side or did you do something else? I'd need to have more information to tell you anything more specific.
Nov 28, 2010 | Kenmore Sewing Machines
JVC12 DISC CHANGER CH-X550 jammed
I would pull off cover, unscrew and remove top carriage of tray and remove your disc. While your at it you should take cotton swab and dip it in rubbing alcohol and clean the laser lens. Then reinstall carriage and top cover and try using it again.
Jun 22, 2009 | JVC AM FM CD DET FACE CAR STEREO
Cannon AE-1 , shutter jammed
The magnetic shutter motor is worn out more than likely. A tech is needed to preform any repairs I would say
May 14, 2009 | Photography
How do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
Oct 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
