Question about Konica Minolta magicolor 2430 DL Laser Printer
Konica minolta 2400w toners problem
when powered on, my printer starts rotating the toners. Immediately after the typical initial rotation, it does a second one, faster this time, and after that, the error light starts blinking slowly. Status monitor says to install cartridge with x color, x being any of the colored ones (usually a different toner each time).
i have removed and reinstalled all toners numerous times but problem persists.
    Champion:
  • 214 Answers
Hei, yes you can buy new toners but usually this problem is caused by toner dust, you have to take out your toners, and clean the contact chips and reinstall your toner. also there is a mechanism whats reading the chips that can be dusty.
Posted on Feb 09, 2008
My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
Posted on Jan 28, 2008
Di2510 toner bottle is not rotating
must have the block that turns the botle toner it works well
remove the toner click on f8 and watch the block rotates or not
Jun 01, 2014 | Konica Minolta DiALTA Di183F Copier
When I start up printer after it rotates the toner cartridges the error light comes on and cannot be cleared . On my Windows computer it says there is no cyan toner cartridge. There is, of course.
Does it say Image Cartridge or toner. Is the cartridge third party if so replace with a real Minolta cart the machine do know info on the chip on the cartridge and reject them sometimes
Feb 19, 2011 | Minolta magicolor 2400W Laser Printer
Power up then goes immediately to code sc23-22 1050 bizhub
Toner pump motor (M28) abnormality. The rotation of the toner pump motor (M28) is checked. While M28 is rotating, an error detection signal (abnormal rotation) is detected for more than 1 second. At this time, error signals (blowout of a fuse and 24V cut off) are not detected.
Dec 14, 2010 | Konica Minolta Bizhub 222 Black and White...
The error light stays on
Hi
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner
hope it can fix your issue
Thanks for using Fixya
Mar 25, 2010 | Minolta magicolor 2400W Laser Printer
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Error light
What kind of error....blinking light which lights are blinking..or is it a code 17h or something like that.....please clarify for me. thank you....whytfang. In the mean time you might take all of the cartridges out and make sure they are in correctly and none are damaged...and then clean the circuit boards and the reading board under the cartridges, then reinstall them and turn the printer back on...if not fixed try again and take care with the reading board...it is delicate...and the chips should be blown clean with pressurized air...like the canned spray used to clean keyboards or other delicate computer components. Try this in the meantime and send me the other info...good luck.
Jan 28, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
276 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
