Advent laptop keyboard removal diagram - Televison & Video
JUST GOT A N ADVENT LAPTOP FROM PC WORLD TODAY BUT THERE IS NOT ANY INSTRUCTIONS ON HOW TO CONNECT IT UP, WHEN I INSERT INTERNET CABLE I AM TOLD THAT THERE IS A CONNECTION PROBLEM, I CANNOT FIND ANY ADDITIONAL SWITCHES ........HELP
Posted on Jul 07, 2008
  • 95 Answers
What model #, not enough information posted to help out.
Posted on Dec 30, 2007
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
M101 keyboard replace
Keyboards are usually screwed in on the top of the laptop as well. Try to pop off the plastic cover above the keyboard, there should be little slots to allow you to take it off. Then there should be some screws under there for the keyboard.
Aug 02, 2012 | Advent Modena M101
Advent 9215 keyboard malfunction
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of computer, refine search to keyboard.
May 20, 2012 | Advent Computers & Internet
How do i find the memory slot on my Advent Quantum Q100?
The Advent Quantum Q100 laptop has one Ram memory slot.
The Maximum Total Amount of Ram Memory is 2GB.
It uses SO-DIMM ram memory that is DDR2 at 667 MegaHertz. (667MHz)
Also known as PC2-5300 {SO-DIMM style}
The Ram Memory slot is under the Keyboard.
Past this point I am at a loss to describe how to remove the Keyboard.
1) Either you have to remove the LED cover above the Keyboard, and below the LCD screen to access screws which hold the Keyboard in place, (Computer off, and ALL power removed. AC adapter {Charger}, and Battery),
OR,
2) The LED cover (Power On button, LED's, etc, are in the cover), has to be removed, and there may be one, or two screws coming up from the bottom of the laptop, which hold the Keyboard in place.
Regards,
joecoolvette
Jun 26, 2011 | Advent Computers & Internet
Hi i have a laptop advent 8109 i need to open it
Remove panel at the back, remove keyboard from prongs at the top, remove HDD, remove screws holding down the laptop, remove heatsink, remove fan, remove ODD connector, lift out motherboard at an angle. Its really something that needs to be shown, but thats the order in which you need to do it. If you can figure out the "in-betweens", you will be on your way to a cheap repair!
Jun 18, 2010 | Advent Netbook
Where can i buy keyboard surround for advent k200
Try Shopping for it at this following website:
http://www.keyboardweb.co.uk/companies/Advent.htm
or Google:
"Acer Advent k200 Replacement Keyboard"
That should do it for you.
make sure you use a walkthrough/diagram/faq to replace it or risk shorting out/ destroying the hardware.
Nov 30, 2009 | Acer Computers & Internet
Avent Laptop 1115C Replacement keyboard
I have the same problem replacements arent cheap though www.adventspares.co.uk £39 +vat apparently part number is 71GL51082-21 hope this helps
Jun 02, 2009 | Recoton Advent Advent Q2035A 20" TV
How to replace an Advent 7000 keyboard?
disassemble your keybr from laptop n using a tweezers to remove old pin n reassemble new pin. using it tool press new pin until "klik" sound.
Apr 05, 2009 | Computers & Internet
Televison & Video Logo
695 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
