Question about Zanussi ZJ1217 Front Load Washer
Sticking on certain programmes.
My machine will only work on some programmes. On other programmes it washes but then does not empty or spin and I have to empty it via the filter.
  • 157 Answers
Try pump you may find on longer programes pump getting to hot..and stalling
Posted on Dec 31, 2008
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Not spinning and emptying
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Zanussi FJD1266W Front Load Washer
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Programmer sticks before the spin cycle (number 5 and 9) on my beko washing machine also if you change programmes the programmer jumps round
Prog jumps as it will carry out 1st command selected unless reset.the sticking could be a faulty water solonoid valve if this happens say during softner fill although could also be the timer /programmer at fault
Apr 03, 2010 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Washes but won't spin...seems to empty water though
Could be the programmer, if its a clockwork one then its common problem, if its a electronic one then your really out of your depth unless you can find another to donate the bits! Good Luck the Yeti
May 19, 2009 | Kenmore Washing Machines
Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint WMA50 Front Load Washer
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi ZJ1217 Front Load Washer Logo
172 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
