Hi
Thanks for using FixYa.
Please check these things to resolve your issue--
Clutch-- It uses a
clutch for agitating the clothes. As the clutch wears out, it may prevent the
washer from agitating well or at all. If the clutch is worn, you need to
replace it.
Drive motor-- Many washer brands
use a reversing motor. For agitation the motor runs in one direction, for
spinning and draining, the other. It's possible for a motor to burn out in one
direction and continue to operate in the other. If this happens, you need to
replace the entire motor.
Drive pulleys-- The motor or
transmission drive pulley may be worn and unable to turn the drive belt. If so,
replace the pulley.
Transmission-- The
transmission could have either of these problems. The transmission may have a
worn or broken gear, or some other internal problem.
Agitator-- The inside of the
agitator--where the transmission shaft attaches--can become worn, and strip out
the spline that allows the agitator to properly grip the shaft. Then the
transmission shaft rotates back and forth as it should, but the agitator
doesn't move properly. If this happens, you may need to replace the agitator
and/or the transmission spline.
After checking these things please revert so that i can provide you with detailed information.
Please revert for further assistance.
Thanks
Rylee
Comments:
Oct 17, 2009
Hi
Disassemble the back panel and check for the part#25 and 24. Also check if there is any oil spill. Make sure that the drive belt is not worn. The drive pulley is part#24 in the schematic.
Schematic--
Click on the schematic to zoom in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
