Question about Smeg A2.2 Gas Kitchen Range
Replacing front panel
The labels for the oven temperature etc on the front panel of my Smeg A2.2 range have been worn off by the previous owner (over zealous cleaning).
I've found somebody who will sell the spare part but my question is, is this easily (DIY) installed? Or do I need a Smeg engineer?
  • BarCar Dec 29, 2007
    Numbers I can find are on label in pan drawer:
    Mod A2-2Type C10V1xx
    N 452 30587
    Is that what you need?
  • sanf Mar 12, 2008
    cleaning). Also my fan has stopped working on normal mode. It works only when the grill and fan is open. I used to work without grill before.
  • 66 Answers
Please write the M# so ican help you
Posted on Dec 29, 2007
  • sohail anjum Dec 29, 2007
    this M# is not comming up. i will try some diffrent .
Oven temperatures now unreadable - worn out. Any suggestions? Thanks
appliance repair shops or online search for replacement transfer decals or replacement panel
Jun 04, 2018 | Smeg Ovens
The light and fan works but no heat comes on in oven.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
I have a smeg SA360X oven. how can I cook without fan force. Cannot understan dials
If this is because the labels have worn off the dials then manuals can be accessed from http://www.smegappliances.com.au/Category-18-Single.aspx
Select the model (closest is probably the SA304X-8) and then download the 50 page manual in pdf format (slow).
Waggabruce
Jun 24, 2009 | Kitchen Ranges
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
My Smeg oven heats up to extremely high temperature even when the gauge is on 50 degrees celcius so I've stopped using it because everything is getting burnt. To identify the model just before the word...
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
Dec 22, 2008 | Smeg Kitchen Ranges
Smeg oven and hob ubit: Fan works but oven wont heat up
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Oct 05, 2008 | Smeg Kitchen Ranges
Smeg Oven not heating to set temperature. Suspect element has blown
if oven does not heat atall, then suspect element.
take back panel off inside oven and element is in view. sometimes the damage is obvious but not always.
remove back of casing and check for continuity thro the element with a multimeter. replacement is easy
Sep 16, 2008 | Kitchen Ranges
Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
I have a Smeg oven SA708, but all of the symbols on the front of the oven (functions / temperatures) have been wiped off by a previous tennant. Just after a picture or diagram of the front of the oven...
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Apr 13, 2008 | Smeg S1100MFX5 Electric Single Oven
Smeg A2.2 Gas Kitchen Range Logo
381 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Steve Allison
Steve Allison
Joseph Mueller
Joseph Mueller
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
