GE 30 in. JGP328 Gas Cooktop
Problem for GE 30 in. JGP328 Gas Cooktop
The igniter on the right front burner of my GE Gas Cooktop
By daphne22 on Oct 17, 2009
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
Best Solution
posted on Oct 17, 2009
Helpful)
milten1
Rank: Guru  GE Ovens & Ranges  Expert
Rating: 90%, 480 votes
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE 30 in. JGP328 Gas Cooktop
Questions and Unsolved Problems for GE 30 in. JGP328 Gas Cooktop
Do you recommend GE 30 in. JGP328 Gas Cooktop?
Answer
Answer
my igniter keep clicking when it is to lite or off
Answer
the cooktop is clicking when the burners are off..two burners stopped lighting
Answer
The front right burner on my GE sealed gas cooktop model JGP328 does not ignite the spark. I smell... (More)
Answer
the ignition on my ge gas cooktop is clicking
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 30 in. JGP328 Gas Cooktop:
Top Kitchen Cooktop Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Cooktop Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
