Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner
Problem for Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH,...
My system is a year old and this morning the heat
By joelongo1 on Oct 17, 2009
My system is a year old and this morning the heat pump won't turn on circuit breaker is fine and manualy had to turn fuel oil on. any idea's I am thinking there must be a switch either bad or cruded up . Thanks Joe Longo
Solution #1
posted on Oct 17, 2009
Not Rated)
1fastbob
Rank: Guru
Rating: 90%, 104 votes
Joe, If the system is only 1 year old I would guess it may still be under warranty. Check with the installing dealer. Might not cost a thing to fix it.
Was this helpful?
Yes
No
Popular Solutions for Carrier 52CQ-312---4 Comfort
Questions and Unsolved Problems for Carrier 52CQ-312---4 Comfort
Do you recommend Carrier 52CQ-312---4 Comfort Series Heat Pump, 12000BTUH, 3.4KW, 265V PTAC Air Conditioner?
Answer
Answer
we cannot control the office temperature with air con system we are freezing! Please help
Answer
I am istalling a Fujitsu mini split heat pum with two zones. I am prepared to pressure and vacuum... (More)
Answer
heater comes on for 3 seconds and then the gas shuts off ..the blower work replaced the thermostat
Answer
Please help me to get unlock nokia 1680
Answer
ochtigheid wasschafte lw 44 6weken geleden aan vochtigheid was toen tussen 48 en 56. nu is het... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Carrier 52CQ-312---4 Comfort...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
