Question about Fargo DTC510 Card Printer
Fargo DTC510 Please answer me! Why couldn't I printing on silver type plastic. Cards gone/run throw this printer but without printing.After that I've seen "card jam", but inside is'nt card. If I use other type (white or other) cards usualy print this card. I've tried to turn off sensor (it help if i use black card) but for this situation don't help for me. do you have ideas for this situation! Thanks a lot. vygis
  • vygis Dec 28, 2007
    but where I could to change " the paper properties"?
  • 82 Answers
The silver-type card contain aluminum powder that's changes the paper properties.
Card can't more electrically charged for electro photographic process, or become more thermally conductive, cooling down the thermal-transfer head...
Posted on Dec 28, 2007
Why is the plastic card becoming jamed in the middle of the printer, it will go forward and reverse though
Really disappointing to hear that. All you need is proper guidance of handling printers there can be some technical issue with the printer. I heard of Plascards engaged in printing of plastic cards may be they can help you. You can also get it printed from this firm or can take assistance from other who have overcome such issues. Hope you get a proper solution soon. Plastic Cards and Custom Gift Cards Printing
Feb 26, 2011 | Fargo Persona C30 Thermal Card Printer
Zebra P110 ID card printer card jam on yellow ribbon.
In the driver go to the tools section. In the command to send to the printer box type !SA then choose send the will calibrate all your sensors. As always make sure your clean the printer.
Mar 17, 2010 | Fargo DTC510 Card Printer
Replacement Parts for FARGO DTC510
Copy and paste the link below into your web browser and it will take you to a site that supplies many of the parts for your printer. Prices are varied, so it depends on how much you are willing to pay.
Hope this helps.
Mar 10, 2010 | Fargo DTC510 Card Printer
My Fargo card printer is eating up ribbon cartridges. I only have one left and they are expensive. Please help
Clean the printer using fargo cleaning cards. Then calibrate the ribbon sensor. Their is a Diagnostic button in the printer driver
Mar 09, 2010 | Fargo DTC510 Card Printer
Card jam
I have this problem all the time with these printers. The solution is to get alchol swabs like the ones you get at the Doctors office and clean the rollers. You will find that it is hard to get at some of them but make sure you get them all including the one that is underneath the turn table. You can spin the rollers when the top is open by pushing the arrows on the display. Also be careful not to hit your printhead in the proccess that this may damage it and in doing so you may see lines running through your cards. Most people think that this will not iprove the proplem all that much but I feel it does wonders. The cleaning kit fargo gives sucks.
Good luck Claude
Oct 24, 2009 | Fargo DTC510 Card Printer
Printing problem
No mag encoder means you're trying to send encoding data to the printer but the printer isn't configured with an encoder. A mag encoder writes data to the magnetic stripe you see on the back of some cards, like credit cards. Most likely, the printer doesn't have an encoder installed, but if it does, it may be turned off in the printer settings.
If you're sure that it does have an encoder, you can check/change the setting by going into the menu on the printer. Go to Menu -> Setup Printer -> Change Parameter -> Encoder Settings -> Mag. It will say none or installed. Note that this can be changed to one or the other whether or not the encoder is physically installed or not. This only turns it on if the encoder is there.
Hope this helps.
Jun 13, 2008 | Fargo DTC510 Card Printer
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Printing problem with silver type plastic cards
Silver-type cards contain aluminum powder which changes the paper properties.
Paper can't more electrically charged for the electro photographic process or become more thermally-conductive cooling down the thermal-transfer head...
Dec 28, 2007 | Fargo DTC510 Card Printer
White Line on Card
unfortunatly is sounds like a "print head" type of problem. By printhead I am refering to the assembly that causes the film to transfer to the card. I would suggest creating a card project that has a full photo as the background. This will show you if the streak runs the length of the card. It could just be dirt or an obstruction in the card path. Try the alcohol cleaning cards. Dissassembly of this printer is a crap shoot. I have done it once. It is one of those things that is best left to someone good at printers or best by someone experienced on these. if all else fails call a dealer like Datacard and ask about depot repair.
Sep 12, 2007 | Fargo DTC510 Card Printer
Fargo DTC510 Card Printer Logo
157 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
