Question about ASUS P4B266 SE (90-M8L22I-B0UAY) Motherboard
It doesn't detect the dram
Thinking that my motherboard supported the sdr i forced the socket and now when I start the computer with my original ddr i hear a long beep in loop. I know from the user guide that my mother board doesn't detect my ddr. the question is "how can i repair my mother board" if it's up to now possible of course.
thank you very much for your help
roberto
    Genius:
  • 1,601 Answers
Sorry,You cant repair it, because you would not be able to get the parts. It sounds like you broke the ram socket or the solder joints around it. Go to tigerdirect.com and pick out a similar one so you can use the same cpu,ram,etc..
Posted on Dec 28, 2007
How can support ram
• Supports two 184-pin DDR DIMM.
• Supports up to 2GB DDR333/400 DRAM.
• Supports 2.5v DDR DRAM.
Feb 26, 2012 | MSI PM8M-V Motherboard
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
What ram compatible with intel845gv mother
Please find the details below:
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845GV
  • Error Detection Support: Non-ECC only
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 2.x Compliant
  • Thanks and regards,
    Anil.B.R
    Aug 17, 2010 | Intel Motherboard
    Which kind of RAM my motherboard is compatible?
    It supports maximum of 2 GB of DDR RAM
    DDR here means DDR 1 and not DDR2 or DDR3
    Rate it, if it helps.
    Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
    Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
    No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
    (BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
    Things to know about the older Sdram ram memory.
    1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
    DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
    Point? All ram from SDR to DDR3, IS Sdram.
    2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
    Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
    This means you need THE ram memory for YOUR eMachines computer.
    Main factors when buying SDR Sdram,
    A.Correct type. You know this. SDR Sdram.
    168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
    B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
    C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
    D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
    E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
    F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
    G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
    H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
    Jul 12, 2009 | E-Machines eMachines Desktop PC
    ASUS MOTHERBOARD P4X-X CAN USE ddr 400
    pls see ur specs here
    http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
    ur board only support following RAM specs u cannot use DDR400
    Memory
    • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
    • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
    pls rate me FIXYA for this help if u like
    Mar 13, 2009 | ASUS P4XP-X Motherboard
    P4S8X-X motherboard. Latest list of compatable RAM 1.gb
    Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
  • Chipset: SiS 648
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Max Unbuffered DDR SDRAM: 3072MB
  • Graphics Support: AGP 8X
  • Jul 06, 2008 | ASUS Computers & Internet
    ECS M925 1.0 sdramm to ddr memory
    The normal DDR Ram is supported..It doesn't support DDR2..
    Nov 03, 2007 | PC Chips (M925G) Motherboard
    ASUS P4B266 SE (90-M8L22I-B0UAY) Motherboard Logo
    48 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Marvin
    Marvin
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
