This fault suggests that you have a bad joint somewhere on the tv. If you feel competent to do so,remove the back and check all lead connections.If secured ok put power on and wait for fault to occur and when it does, listen for any arcing or strange buzzing noises coming from the power supply. If so, there may be a dry solder joint on the power supply. Also check for bulging capacitor tops with possible brown fluid discharge on the central power supply board..If this is present, replace the capacitors..Samsung plasma tvs are prone for this, and if ignored, eventually the tv will not come on at all and keep tripping on and off.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung HP-R4252 42 in. HDTV
i would really like the part # of the board i should replace, rather than looking for a bad solder...
(More)
i would really like the part # of the board i should replace, rather than looking for a bad solder joint. thanks
Just recently this TV is getting has a few black lines about 3" thick that go up and down and...
(More)
Just recently this TV is getting has a few black lines about 3" thick that go up and down and across the screen. There are big squares of purple, red and green snow.
our 42 inch samsung plasma screen is nearly black,its about 3 years old..model # HP-R4252 any...
(More)
our 42 inch samsung plasma screen is nearly black,its about 3 years old..model # HP-R4252 any suggestions ?
I have a Samsung HP-R4252 for about 4 years, I'm getting reddish,pinkish Horizontal line on the...
(More)
I have a Samsung HP-R4252 for about 4 years, I'm getting reddish,pinkish Horizontal line on the upper half of the screen. What could be the problem and cost to fix?
