Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
MY RCA TVE WONT TURN ON
I HAVE AN RCA MODEL NUMBER D52W20 IT WONT TURN ON IF i TURN ON THE TV THE POWER LIGHT TURNS ON BUT NO PICTURE AND SOUND THEN IT SHUTS OFF WHAT IS IT?
The TV timer is blinking (red) and when I turn on the TV it switch off automatically after 5 seconds. I pressed the reset botton on the remote but still it didn't solve the problem.
    President:
  • 4,402 Answers
Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below.
Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry. TV is powering off most likely to protect itself from the shorts.
Posted on Jan 14, 2008
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA rear projection wont turn on the light flashes when i push the power button, i got it to turn on once and i had a vertical line running through it. and colors a little distorted, i tried in the menu...
The flashing light opposed to a solid pwer indicator light usually means it needs to be serviced. I wouldn't reccomend home repairs, but repairs sometimes cost more than the product. You should compare prices and such before making your move.
Aug 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Did you change your battery from the remote?
Dec 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
