Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Dryer doesnt always work
My washer /dryer works fine in wash mode but then when i use the dyer sometimes it will dry perfectly but then the next time i use the dryer the washing comes out soaking wet and steaming hot so then i have to spin it all again
  • Anonymous Jan 07, 2008
    hi my washer / dryer also does this but has also had water pumped in towards the end of the drying prog had any ideas on what the problem is
    Sergeant:
  • 271 Answers
It is your stat its the white one when you take the lid off its right down in fount of you make sure you unplug the machine take it out and take it to your local appliance shop they should order you one there really cheap £3.00 it don't mater where the weirs go theres only 2 of them they will go on the new stat the same way you took them off the old one
Posted on Jan 07, 2008
Washed ok but when put on drying mode it made a loud grating noise
The drying fan is most likely clogged.
Take of the topp, then you will se the drying fan. Along with the heating system. There are several screws you have to undo on the heating canal. Then you should be able to clean the whole thing.
Sometimes the fan is broken, and need replacing.
This is not recomended if you dont know what you are doing!
Do a mistake with the overheating guards, heater position, wireing ect, and you could set the machine on fire the next time you use the dryer
May 14, 2014 | Hotpoint Washing Machines
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
The dryer does not dry
time to clean the lint filter and the exhaust pipe (the large, white flexible hose) which could be filled w/ lint
good luck
May 20, 2009 | Whirlpool LTE5243D Top Load Stacked...
No manual for Defy Kombomaid - cant get dryer to work
The dial to the left operates the dryer. Select amount of drying time, push same start button as for washing machine and voila! Also you can go directly from wash mode to dry mode without machine pausing. Select your wash cylcle, your drying time and push start.
Apr 14, 2009 | Dryers
Dyer malfunctions
Clean off the two metal bar inside the drum, near the lint filter. (these are the moisture sensors, which can become coated with fabric softener sheet residue, preventing the dryer from "seeing" that the clothes are still wet)
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer Dryer
washer dryers work by using a fine jet of cold water to condense the steam from your clothes drying. therefore, water has to be turned on when in the drying mode. make sure water is on.
after that, if water is in fact turned on, then the fault will probably lie in the valve being open circuit
Jul 06, 2008 | Washing Machines
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Doesnt always rinse.
now the problem with this is a faulty solenoid situated at the back under the lid were the pipes attach should be the 1 with more exit pipes coming from it change this and should work fine m8
Nov 16, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
