Question about Compaq Presario 5000 PC Desktop
Screen My computer sreen turns translucent blue and diagnol lines appear. Though I can work as usual but can hardly see.It comes and goes again and again on its own.
  • 3 Answers
Sounds like the monitor is going bad. I had this happen too and had to replace the monitor and it's been great since! If you can work fine, it's not the computer itself, it's the monitor.
Posted on Dec 28, 2007
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Ipad 2 has a transparent line moving across screen
have you tried a hard ware reset?
turn off device, then hold the power button on top and the home key (make sure its not plugged in also)
keep Holding both keys... you will see the apple logo appear, and then flash off, and then it will restart again. If you keep holding the home key and the power key, it will continue in this loop. Holding it until it reboots once should be enough though, then just turn it on and let it boot normally.
Your settings and everything should remain the same, this just will reset the hardware on the device. I have had issues with my iPad 2 with games lately, mainly random crashing, when I do this hardware reset, it usually fixes my crashing issue for a while.
Once again the steps are:
Shut off device, make sure it is unplugged
Hold the Power button and home key, until the apple icon appears and then flashes off.
Let the device turn on normally, let go of home key and hold the power button till the apple icon appears, and let it boot up normally.
Test the application, this may or may not work. But its def worth a try.
Mar 07, 2014 | Apple iPad Tablets & eReaders
Blue screen of death
usually blue screen is shows when there is a problem on your computers memory on your hard disk drive,first try to clean the memory by using a clean paper on the contacts of the memory that is usually copper in color then after cleaning if the blue screen comes again try to replace a good memory if the blue screen appears again then try to reformat the hard disk drive which is the final solution to your problem.. hope this helps you
Jul 25, 2011 | Asrock P4I45GV R5 Motherboard
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wierd Static
it sounds like you may be having problems with the cable that connects to the tv, have you tried a new/different cable?
Jan 30, 2009 | Atari 2600 Console
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Blue screen on everything
Blue screen usually means no signal coming from the source. Did you accidentally hit the 'source' button on the remote, so it is now set to the wrong device (DVD player instead of the cable, for example)?
Jun 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
