Question about Casio Exilim EX-Z750 Digital Camera
Casio exi-lim Ex-v7
Camera appears to turn on - it beeps and green led flashes but screen and zoom do not apear to function. Without the screen can not tell what is going on. Unit is christmas present.
  • Chancess
    Chancess Dec 29, 2007
    Yeah iv got the same problem i turn on the camera, the lens comes out it beeps and green led flashes then turns off again :( HELP?!
  • 374 Answers
Try this. If the power stays on press menu. Go right twice, go up once, press right once, press up once and then press set. That should reset the camera. If that doesn't work then you will have to send it into repairs.
Posted on Apr 06, 2008
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
Exact same troubles.
i think you've got a stuck zoom in [+] button. was this camera left inside a cabinet ...or some damp place for some time?
Jul 15, 2009 | Nikon Coolpix 2200 Digital Camera
Camera stabilizer not available
You should update a firmware to new version 1.03 / download from Casio site / . It will allow You to take pictures without camera stabiliser.
This problem with camera stabiliser needs lens alignement in authorized service.
Oct 08, 2008 | Casio Exilim EX-V7 Digital Camera
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Casio Exilim z75 - unable to take pictures
Try shutting off your flash and see if it still does that. It sounds like you have a problem with your flash not charging correctly. You can try resetting the camera but I doubt if that will help. I would try just shutting the flash off and see if that would help.
Aug 26, 2008 | Casio Exilim EX-Z750 Digital Camera
Camera beeps and won't turn on
Try playing with the lense I had the same problem. I would turn it on and the screen was frozen, the three beeps then it turned off. I played with the lense since it was sticking out and I tried turning it on again and it worked. :]
Jul 24, 2008 | Casio Exilim EX-V7 Digital Camera
LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
May 26, 2008 | Casio Exilim EXZ75 Digital Camera
Dropped the EX-V7 in China and it went blank.
Here is the contact information for the Hong Kong branch
HONG KONG HONG KONG JEBSEN & CO., LTD. 852-2926-2300 852-2926-2307
Apr 18, 2008 | Casio Exilim EX-V7 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
89 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
