Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the
camera may require professional repair.
Why do I get horizontal lines running across my images? Is there anyway of removing these using...
(More)
Why do I get horizontal lines running across my images? Is there anyway of removing these using photoshop or a camera setting?
I can't get the flash to come back on the camera on any setting?? Any help would be great. Thanks,...
(More)
I can't get the flash to come back on the camera on any setting?? Any help would be great. Thanks, Nez
i droped the camara and the lens is stuck out and it just comes up with try turn off and then on...
(More)
i droped the camara and the lens is stuck out and it just comes up with try turn off and then on again??aany ideas and how much to fix???cheers sony cyber shot w200
