Question about Digital Cameras
Panasonic fz7 I have a  Panasonic 8.4V DMC-FZ7 Model no- L6SU01 145 R, and I bought a 2 gb transcendua sd card from Dick Smith the sales man looked at my camera and fitted the card in for me. Problem is I took heaps of photos Christmas day and when I tried to load them on to my pc an error came up saying format card I don't want to do that and lose my photos that I can see on the camera screen. What should I do Thank you Sandra
Re: panasonic fz7
try check the support driver of the camera , do you install the driver of the camera on your computer? does the picture in your camera? on screen? during scanning manully .If the picture appear on screen return to Dick Smith what compatible computer or operating system to be use maybe the latest virsion of the system . Thank You,
Posted on Dec 28, 2007
0 characters
3 Points
What size memory card do I need for a panasonic
The DMC-FZ7 works with MMC and SD cards, 2GB or smaller.
Be careful when buying a card, the camera does not work with higher-capacity SDHC cards.
Sep 29, 2014 | Digital Cameras
I have a Panasonic Lumix DMC-FZ7. The problem is it doesn't read the memory card anymore. It keeps saying, "Memory card error. Please check the card." is there a quick fix to this or is this...
Ok, came accross this problem. After searching and searching, I downloaded the user guide ( who knew?! ) and the reason that is happening is because the Lumix DMC-FZ7 is not able to process an SD card bigger than 2 GB.
I switched it to a 1 GB and camera is back working!!
I hope this helps
Jul 15, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a 4 and a 8 GB card and both do not work in my cam only the 2GB cards i have do, Help
Due to the FZ7 being developed pre - SDHC it will only support standard SD cards.
SD cards are only usually found in sizes up to 2gb, then with the advent of SDHC (the HC meaning High Capacity) bigger size cards were produced at the cost of backward compatibility.
SDHC was added in the FZ8
I have heard it is/was possible to get a 4gb in standard SD card rather than SDHC, but they are very rare and probaly only available 2nd hand these days.
Mar 02, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
My Panasonic Lumix DMC-FZ7 will not read memory cards. It displays "MEMORY CARD ERROR, PLEASE CHECK THE CARD"
It wants you to format the card in the camera. This will erase the card so download any pictures on it first using a card reader if necessart.
Oct 14, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Problem taking pictures after number 48 is shot.
Are you using a panasonic SD card? The camera may not function properly when a cheap SD card is used.
I also have a FZ7 and it works better with a memory card of the same brand.
Also, if the card or the camera are old, they may be worn out.
Jun 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
MicroSD SanDisk 2GB memory into Panasonic DMC-FZ7
Hey filmoman2008,
If you are really trying to use a micro SD card this camera actually takes normal SD memory cards not micro SD cards.
Go Ahead. Use Us.
Apr 25, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Digital Cameras Logo
145 people viewed this question
Top Digital Cameras Experts
Are you a Digital Camera Expert? Answer questions, earn points and help others
