i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water doesn flow but warm water yes. Please help
Comments:
Oct 18, 2009
- I Answer your questions:
when set on 'hot', do you get hot water? YES
set on 'warm' you get warm? YES but more amount of warm water falls inside the washer than hot water
set on 'cold'? cold water splash comes out very small, almost drops.
You said "I am not if you get warm on 'warm', then it's mixing hot with cold- so, could be a fault in your temp. setting control." but why the amount of water change as the control moves to cold water while it is washing? (I have to add cold water with a bowl to washing is not delayed.)
when set on 'hot', do you get hot water? set on 'warm' you get warm? set on 'cold'- nothing? if you get warm on 'warm', then it's mixing hot with cold- so, could be a fault in your temp. setting control. please clarify! good luck!
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting...
(More)
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting in best for my requirements. Thank you, Donna
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I...
(More)
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I can't close it as if I press the grey knob the door just presses into the drum. I think both springs need to be replaced. How do I replace the springs and what are the part numbers. Thank you, Gill from Scotland.
