Question about Sony VAIO VGN-N130G/W Notebook
Replacing Hard Disk Drive
How to open the notebook for replacing new hdd in it
  • Anonymous Jan 12, 2008
    could you elaborate on removing the top plate....I have a bad drive too..there are a total of 17 screws on th bottom and it isn't clear what they will release or difficult it may be to re align
Unfortunately, for the sony vgn-n130g notebook, sony started design from merely a machine screw. they then built the entire computer around the screw. unfortunately, this screw's access is necessary to remove the entire top plate assembly to gain access to the HDD. Why doesn't Sony just mke an access plate like anyone else?
Posted on Jan 08, 2008
  • 625 Answers
All machines are slightly different for accessing the components, but if you flip over the laptop look for some screws on the bottom that hold an access plate. the hard drive is about three by four inches.
Posted on Dec 28, 2007
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Dropped notebook, get only black screen, error loading operating system.
The notebook needs to be opened to see if the hard disk drive (HDD) has simply become detached from it's slot and slotting it back in fixes the problem. Alternatively, if the HDD has suffered shock damage from when it was dropped, a replacement HDD might resolve the problem but the Operating System, drivers and programs will have to be installed on the new HDD.
Sep 18, 2011 | Acer Aspire One PC Notebook
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Sep 19, 2010 | HP ProBook 4510s FM849UT Notebook
Hdd is not getting detected it is new hard disk the hdd is 160 Gb,cables are good solution to be not to open hard disk
u have installed the hdd properly
but not the bios..
open biios
press <del> or the key suggested by the computer when the computer boots.
u will enter bios...
now go to boot section
make first boot as the hdd shown in the list....
save the settings and reboot.
if it fails ..
unplug ur hdd. a and plug it again...
and follow the instruction again
Mar 11, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
Hdd primary pasword is lost cannot open hard disk drive showing error codes 06231 and so on cannot boot the computer cause the disk drive is asking for primary hdd pasword and is no taking the password...
Most modern laptop HDD or BIOS passwords are not resettable and don't come with default passwords to unlock them if the password is forgotten.
You will need to contact Acer and find out what kind of warranty coverage your machine has. It's likely that you will have to pay for the services they provide or pay for a new hard drive yourself and re-install Windows.
Aug 10, 2009 | Acer Aspire 5535-5050 Notebook
Replacing HDD in ACER 2920Z
never use internal HDD without knowing. Use same old HDD and use external hard dsc now u brouught 320 sata use casing now
Jun 18, 2009 | Acer Aspire 3690-2900 Notebook
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
OPEN Sony VAIO VGN-T330FP TO CHANGE HDD
turn the laptop upside down ...remove a partial plastic cover attached by a screw on its edge ( there is a small sign showing the hard drive usually) after taking the cover of plastic away the hard disk is visible . pull it gently aside (sideway)
and replace it with the new one.
May 29, 2009 | Sony VAIO VGN-T350 Notebook
External Toshiba 400GB HDD not recognized on my Dell CPx J650GT
New hard drives need to be formatted! So go into the control panel switch to classic view, ( if you are still using category view for the control panel ) open administrative tools, then open computer management. Next open disk management. In disk management your new drive will show as raw, you will be give the option of formatting the drive, select primary partition and format in NTFS.
This will then format the drive, when this has finished your new drive will appear in my computer.
Alan
Jan 18, 2009 | Dell Latitude CPX Notebook
Sony VAIO VGN-N130G/W Notebook Logo
320 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
