Most likely it is the lamp. Open the lamp door and check the lamp visually. If it is shattered or cracks. Also if there is a cloud near the stem of the lamp, the lamp has reached the end of it's serviceable life. Replace the lamp to fix it. If you need further instruction replacing the lamp, there are step by step directions available in your owner's manual with pictures. If you lost the manual, download it in PDF format from Sony's website for free.
My Sony kdf e60a20 turns on and off and sounds goes off also. Has just started in last month after...
(More)
My Sony kdf e60a20 turns on and off and sounds goes off also. Has just started in last month after 3yrs of use. is it the bulb finally?
I have a Sony kdf e60a20 tv, the video&audio go out, while the green power light stays on,...
(More)
I have a Sony kdf e60a20 tv, the video&audio go out, while the green power light stays on, no blinking lights at all jus audio&video going in&out, CAN SOMEBODY PLEASE HELP???
Shuts down periodically and then comes back on.No other problems when operation. Appears to be heat...
(More)
Shuts down periodically and then comes back on.No other problems when operation. Appears to be heat related. Any ideas?
