Question about Canon EOS 400D / Rebel XTi Digital Camera
CF error I own a Canon 400D. It worked perfectly until today. I inserted the cf card, and turned on the camera. It took a couple of seconds to light up, and I got a message that the cf card was faulty and needs to be replaced. I used another one...it said the same thing. I tried reformatting. It gave me an err99 and then said that "shooting is not possible" I formatted the card on the computer...no luck. The pins are in place, I checked. What could be the problem and how could I go about solving this? Thank you.
  • 5 more comments
  • happyfeet2 Jan 02, 2008
    Yes I encountered the exact same problem with the CF card..the same scenarios, etc. What to do now?
  • karolann Feb 07, 2008
    same thing exactly
  • VBDon Feb 17, 2008
    I'm having the same problem. My first card, a Lexar 1GB worked fine. The second was with a Samsung 8GB card, which produced the 99 error code, even after formatting on my PC. I returned it and got a Samsung 4GB card that was listed as Canon compatible. It produced the error at first but when I formatted it using my PC it worked. Later I bought a 2 GB Kingston and now the error comes up on all three of my cards.
  • sakshi mahajan
    sakshi mahajan Feb 17, 2008
    i own a canon 400d 18-55mm... bought it like 2 weeks back!!! today after i transfered da pics from my camera to my pc and tried formating the card... it wasnt able to do so.!!!
    # i tried using another cf card too, but found no result...
    the same error 99 wz being displayed!!!
    # wen i tried clickin pictures... it showed a note sayin that the cf card needs to be replaced...but wen i tried formatting it showed a note saying turn off and then again turn on... and insert the battery!!! i did but found no result!!!
  • tmcca Mar 01, 2008
    I received my new XTi today (Sat.) very carefully put it together , put on lens, installed CF card, charged the battery, installed battery, turned it on. And POW!!! The same thing happened. Error reading on CF card, I then tried to
    format the the CF card. Got an error that said Change the battery, I put a spare battery in same thing again. Error 99 again.
    Ted
  • happyfeet2 Apr 10, 2008
    Hi this is me again, Happy Feet. I encountered this problem shortly after first use. I had removed the card and then reinserted it. It appears, that somehow the pins bent. (I was very careful). I called Canon and since the camera was less than one year old they told me it was under warranty. I had to send it to them for repair. Cost to me... shipment and insurance only. I am afraid to use it however as I fear it will happen again. I don't think I will ever remove the card once I install it. I think this is a flaw with the camera. I love Canon cameras but I regret buying this because it uses the Compact Flash card. Wish it used the SD type card. Oh well. If under warranty, call Canon for repair. Good luck.
  • blballet Apr 27, 2008
    I was shooting and suddenly got the CF error telling me that there's a problem with the CF card. I tried to use my PC to download the photos and there was no image available. What should I try next?
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Posted on Jul 05, 2008
    Problem Solver:
  • 11 Answers
Canon have a few different ERROR codes (eg ERR01, ERR02 etc) BUT if there is any other fault with the camera that is not covered by them it comes up with ERR99 (vaguely saying ANY other fault!)
Some of the problems above may be the CF card holder pins being damaged - Have a look in the holder if you can, there are longer pins at each end & the middle, they are the ones that show any damage first. Needs to go to a repairer for that one !
Some of the problems above could be down to the cards being formatted on the PC. Always best to use the camera to re-format the cards. Sometimes the PC can re-format the card with the wrong configuration causing the ERR99.
Hope this helps someone
Posted on May 08, 2008
Usually 99 error means a problem with the lens, try to change the lens, or connect it all the way (i.e. until you can turn it anymore). I had a Sigma lens that didn't work with my new digital Canon. it also gave me 99 error and then 2 months ago, a canon lens gave me the same problem, check the lens.
Posted on Mar 20, 2008
    Problem Solver:
  • 6 Answers
Error 99
This is a broad error for hot shoe issues and the lens electrical contacts. People have complained about this and it was never related to the memory card. The most common cause for this error is the lens contacts though. On the body, being very careful - check the contacts for oil or dirt. You can take a clean pencil eraser and gently wipe the contacts (making sure not to let shavings or anything get into the body!). Do the same for the lens and try it out. Many people have reported success after this process. Good luck.
Posted on Mar 18, 2008
I sent it in for a repair to canon, came back good as new with no charge.
Posted on Feb 20, 2008
I recharged the battery to full capacity. Still, the camera still reports a code 99 error on all CF cards. I'll bring the camera in to work with me tomorrow and call Canon for warranty service. Unfortunately, this means I'll miss photographing the lunar eclipse tomorrow night. Oh, well!
Posted on Feb 19, 2008
  • 36 Answers
Did you try replacing the batteries?
Posted on Dec 28, 2007
Cf card error
The file system on your CT memory card can be corrupted. It only takes one second, when you not watch the access light on the back of the camera, when you pull out the memory card. If the card does not contain any pictures, just try to format it. If it won't work in the camera, try to format it in an external card reader connected to a computer with an older operating system then Vista. Give it a format FAT 12 or 16 for the smaller CF cards (less than 2 GB) and FAT32 for the bigger ones.
If this works, don't forget to let the camera do a format to, just to make sure the card can be used by your camera.
Feb 01, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
CF card error message
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you can take it to be professionally repaired by replacing the card reader. But you may also want to consider repairing it yourself by unbending the pin.
To do so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started.
Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99
i had the same problem and i found this guide online fixed my problem
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon A85 power on problem
I think we can rule out a problem with the cards, which leaves the camera. maybe one of the cf pins is bent?? look into the slot with a light and check for any pins out of line, if you find any, see if you gently push it back into place. I saw the exact same problem, having the same fix. try also connecting AC through a cable and the camera to the computer, see if it makes any change. Whats your warranty status? use it if you still got it, if not, get a repair estimate. Hope it works out
Feb 12, 2006 | Canon PowerShot A85 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
686 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
