Question about Car Audio & Video
To Remove a radio from a Peugeot 107
Hi I need to remove the radio from my peugeot 107 so that I can fit a Bluetooth Mobile phone kit can you help
  • Billy Fordham Dec 29, 2007
    Its a 2006 5 door urban
  • Anonymous Nov 28, 2008
    peugeot 107 radio cd removal
Remove fan control knob and unscrew Philips screw behind it. Firmly put the panel from lower section where fan control was, the six clips will give way, usually loudly. The head unit comes out with panel, inspection off inside panel will show metal clips holding stereo in place, squeeze clips to remove stereo from panel, don't forget to dissconnect the wires. Obtain 107 fascia for fitting single iso head unit, makes is look better. Follow instructions for fitting new head unit. Fascia not required to refit original unit and unit is not coded.
Posted on Mar 06, 2013
    Scholar:
  • 143 Answers
What year is the car?
Posted on Dec 29, 2007
    Champion:
    Scholar:
  • 216 Answers
Disconnect car battery.
You better have code for the radio or you will be screwed.
Using a screwdriver, remove all screws from panel holding onto radio. Some panels may have clips, just pry out gently.
If I remove my radio will there be a inline 15amp fuse there because my radio is not working in my Peugeot 207 2012
check the car fuse boxes first as in your handbook. the audio fuses are nomally in them unless you have a non standard fitted system then the fuses could be behind the radio
Feb 27, 2017 | Peugeot Cars & Trucks
Where are the two immobiliser transponders located on a peugeot 107
Usually a chip in the key fob and the other is in the ignition lock or close to it under the dash. When paired they talk to the ECM - engine control module and release power to the ignition system.
Peugeot
Jun 22, 2016 | 2007 Peugeot 107 1.0
My peugeot 107 urban 2tronic is making a continued beeping noise when accelorating. When i ease off the accelorator tho it stops. It also over revs and is quite sluggish. 1t is a 2008 model.
Hi, I am sorry to say this but I had exactly the same problem which got worse with time. I took it to a peugeot garage and apparantly it is a common problem with these cars at 40,000 miles. The gearbox and clutch had to be replaced leaving me with a massive bill of 2,400 for repairs. Good luck with yours and thank you peugeot for what will be a very lean xmas.
Jan 29, 2012 | Peugeot 107 Cars & Trucks
Hi, I changed battery for peugeot 106 zest 2 y reg and radio stopped working. and I need code.
remove the radio and check the casing for the radio code. Most dealers fail to remove the sticker identifying the radio with the car when in stock. Failing this you will have to take the car to a Peugeot dealer where they will retrieve it from their database. Hope this helps...
Mar 04, 2011 | Car Audio & Video
I need the radio code for my peugeot 206, v reg
Hi
If you contact the peugeot dealer and give them the car reg number or chassis number, providing the radio is a standard peugeot radio they should have the code. its about £20 I think alternatively look copy and paste the URL or click http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1313&_nkw=peugeot+radio+code&_sacat=See-All-Categories
There are many people on ebay who can decode the radio if you know the number on the side of it.
Hope this helps
Regards
Dan
Jun 21, 2010 | 1991 Peugeot 405
Hi I have a parrot hands free kit which was
You can purchase a special adaptor lead to allow the parrot to just plug in to the back of the radio, this is called a SOT lead, do a web search and you will find the right one. Try autoleads or kram are good manufacurers.
Jun 17, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Upset Granddad. Removed his radio and don't have the code.
The other number (apart from the main Serial Number ) required for a Peugeot Radio Code is the SECURITY CODE which is in the format TOA123 or TA123 or just A123 at the end of a barcode.
What I suggest is POST A NEW QUESTION quoting ALL the LETTERS+NUMBERS from ANY LABELS , BARCODES or STAMPED IN THE METAL CASING and I should be able to help
Sep 19, 2009 | Car Audio & Video
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Car Audio & Video Logo
2,649 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
