Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W TV made loup popping sound. Pulled the lamp and it's fine. However, behind the glass window that faces the lamp are several broken fragments of glass. Is this a broken color wheel?
  • sandmail Dec 28, 2007
    Color appears to be a variety of colors including a dark bluish tint. It's located behind the window inside the TV and only viewable once the lamp has been pulled out. The lamp is in great shape. I've replaced 2 lamps myself in three years and know what one looks like when it's fried. The color wheel was replaced once before due to the infamous grinding noise, but never heard of on shattering either. It's literally in dozens of small pieces all piled behind the window. The TV shut down with the three blinking lights and would not fire up. If the color wheel directly faces the lamp, I'm almost sure that it's what shattered.
  • simonooch Jan 14, 2008
    When I power up the TV the lamp light flashes and I get a 3-4 second beep or alarm code. This happens 3 times and then the TV powers off and all three leds flash. Could this be caused a defective color wheel? I have a replacement lamp and it has the same result. Also, if it is the color wheel, where can I get one and is it difficult to replace?
My Color Wheel did shatter, I was able to replaced it myself and it fired up again. If you replace it yourself, take your time and document each step and label everything. It takes about 1 - 2 hours from start to finish
Posted on Jan 05, 2008
  • 934 Answers
If it is it will be the first I've heard of one shattering... The CW spins at 7200 rpms and at that speed anything is possible. What color is the glass?? Clear and it's not the CW.. My bet is on the lamp. Does the lamp fire up?? You need to do a bit of investigating and let me know and I'll try and help..
Good Luck!
Bill
Posted on Dec 28, 2007
Samsung dlp made a popping sound now only have sound and tv turns itself on and off. All 3 lights on front were flashing. I took out lamp...it looks fine....thought I would put it back in when I noticed...
You have a good eye, that would be the color wheel. You can call samsung at 1-800-samsung to find a repair center, it is not an easy job to replace it yourself.
Aug 15, 2011 | Televison & Video
My 46" Samsung TV -
The first thing to do is with the set unplugged remove the lamp the set uses (customer replaceable) and examine it to see if shattered inside.
Lamp door is either on side or rear of set, once door is removed you will find the lamp cartridge which is secured by two brass screws; with them backed out grasp the handle on the cartridge and pull lamp and cartridge out.
Do not touch the face of the lamp but look inside the glass--if it looks like a 1950s style flashbulb with bits of broken glass, you have found your problem.
before you rate this information let me know what you find and what questions you have; make a comment here and the site will email me.
SD TECH
Jul 09, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Jun 09, 2010 | Samsung HCL4715W 47" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
When I turn off my Samsung DLP it makes a pop and a sound like ''Glass breaking'' about 1 to 2 seconds after the picture and sound has stopped.
Hi,it sounds like its the lamp,when it goes out lamp will pop and you'll hear glass inside of it.Make sure you get the original Philips lamp.Also check the color wheel here;s how to take it out: http://guides.fixyourdlp.com/samsung/bp96-01579a.php It might be that color wheel is broken and that's why you hear glass breaking because it might still spin broken.God bless you!
Sep 30, 2009 | Samsung Televison & Video
No picture but sound once it goes off there is 3 blinking lights
Most likely for this symptom is the lamp. If you'd like you could sit behind the set and have someone turn it on, you should hear the color wheel spin up and then you should hear the ballast try to fire the lamp, it makes a small arcing sound. If the lamp doesn't light the process starts over again.
Jan 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
