Home | ASUS | P5VD2-MX SE Motherboard | Computer either reb...
ASUS P5VD2-MX SE Motherboard
Problem for ASUS P5VD2-MX SE Motherboard
Computer either reboots after 1 hour or less.
By midnitemoong on Oct 17, 2009
Computer either reboots after 1 hour or less. Sometimes it stays on for a bit longer. If not the screen goes black but the computer is still on. Also there is a cable that is disconnected but I have no idea where I'm supposed to plug it. It's connected to one of the hard drives.
Comments:
Oct 17, 2009
- Is it normal for the drives to get very hot in a short amount of time? Also about the screen going black but the computer is still on can it a problem with graphic card? I can't afford to have fixed that's why I'm here...
Oct 17, 2009
- <You have to check the SMPS volatages are ok> What are the SMPS? Sorry but I'm newbie...
Best Solution
posted on Oct 17, 2009
Helpful)
latheefp
Rank: Guru
Rating: 87%, 36 votes
Dear,
Is is not the issue with cable, if machine comes up without that cable, which means this cable is not mandatory. This issue may be due to memory or any loos contact in motherboard also. You can swap your system momory and see. IF you are not technically well, get some help from skilled person.
Comments:
Oct 17, 2009
- Dear,
If your drive is going very hot withing a short time period, that may the reasone of this issue. You have to check the SMPS volatages are ok
And, if possible chek your drive on other machine how it perform with heat
And you can discunnect the drive and keep the machine in CMOS (without booting) for long time and watch
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for ASUS P5VD2-MX SE Motherboard
Questions and Unsolved Problems for ASUS P5VD2-MX SE Motherboard
Do you recommend ASUS P5VD2-MX SE Motherboard?
Answer
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Answer
Dear sirs I had a hardware defect that can be defined as a component severely damaged by little fire... (More)
Answer
Report abuse posted by lanang22game on Mar 29, 2009 No Sound in Vista Ultimate Mobo P5VD2-MX SE... (More)
Answer
merhaba anakartim hdd usb gibi goruyor. bunu nasil cozerim
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS P5VD2-MX SE Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14739
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
